forward control extensions
Old Oct 24, 2010 | 08:32 AM
06 fxstbi's Avatar
06 fxstbi
3rd Gear
Default forward control extensions
it was suggested to me that I may look into forward control extensions. My local Harley mechanic said "No problem to three inch extensions, just a bolt on adjustment."
But, It appears to me that the shifter linkage and the brake line would need to be extended also.
Am I correct? What difficulty will I experience? Any insight is greatly appreciated.
Old Oct 24, 2010 | 09:01 AM
wiseguy2day's Avatar
wiseguy2day
I have the Arlen Ness version on my softail. It comes as a whole kit with the linkage, brake line and everything you need except new brake fluid. It's not that hard but if your unsure how to bleed your brake line have someone help you with that part, or look it up on youtube.
Old Oct 24, 2010 | 09:26 AM
magnum629c's Avatar
magnum629c
the Arlen Ness kit is great and is very easy to do.
Old Oct 24, 2010 | 09:51 AM
06 fxstbi's Avatar
06 fxstbi
3rd Gear
By the way, I am 6' 3", there is the "why."
Thank you very much with info on the "how."
Old Oct 24, 2010 | 11:28 AM
Mr. Lucky's Avatar
Mr. Lucky
Just take your time and it's an easy job. Cycle Visions also makes 2" and 3" extension kits, and unlike the Arlen Ness units, they are powdercoated black (not anodized) to match the stock controls.
Old Oct 24, 2010 | 02:41 PM
brettnbama's Avatar
brettnbama
I have the Ness kit and like it a lot...
Old Oct 24, 2010 | 03:19 PM
richmac64's Avatar
richmac64
I used the Ness extension kit and it's black powdercoated also.
Old Oct 24, 2010 | 03:37 PM
Ash16's Avatar
Ash16
I have the Ness kit also. It was easy to install and the ride is much more comfortable.
Old Oct 24, 2010 | 03:38 PM
magnum629c's Avatar
magnum629c
I found the Arlen Ness version to be the best ! In fact once its done unless ur looking for it you will not even no its there. I was very happy with the parts they seem very well made.
Old Oct 24, 2010 | 05:53 PM
Mr. Lucky's Avatar
Mr. Lucky
It's advertised as black anodized, which is why I bought the Cycle Visions kit.
"Each kit includes black anodized billet aluminum adapter plates..."
http://www.denniskirk.com/jsp/produc...=&skuId=573727
