Squeeling Front Brake
Old Oct 26, 2010 | 02:20 PM
Beachman's Avatar
Beachman
I had the same problem I switched to Lyndall pads and cleaned the pistons. The noise stopped and the the pads do not stay in constant contact with the rotor any more either.
Old Oct 26, 2010 | 06:33 PM
user 6974208923's Avatar
user 6974208923
So, how do you safely clean the pistons? Procedure??
Old Oct 26, 2010 | 10:17 PM
harleyheaven's Avatar
harleyheaven
Originally Posted by pepper lynn
So what is the name of the stuff?
It is in a small plastic bottle.. has the initials NF at the top and says "Disc Brake Squeal Silener".
The bottom of the bottle says, "The Noise Free Company".
It is not glue but it sets up and holds the pads to the cylinders. Removing the pads was no problem.
Old Oct 27, 2010 | 03:25 AM
Papawolf's Avatar
Papawolf
1st Gear
You can also go into a car part store and at the counters they will have little packets. Look for one called barke grease, and make sure it is the one that goes behind the pads. This holds the pads to the pistons and stops the noise and leangthens the wear time.
Old Oct 27, 2010 | 08:10 AM
Beachman's Avatar
Beachman
Go tho the lyndall Racing Brakes Web site. They have a step by step procedure for cleaning the pistons. It's easy.
Old Oct 27, 2010 | 08:23 AM
Beachman's Avatar
Beachman
I also forgot to mention that I lubed the brake pistons and the pin that holds the pads with Versilube. This is what the HD manual specs. The only problem is that this stuff is hard to find. I think it may come with some brake kit that HD sells. I found mine on line. I had to buy a 8oz. tube around $30.00.
pcmc2
2014-2024 Touring Models
17
May 23, 2017 06:15 AM
89FLHTC
EVO
55
Mar 16, 2016 07:40 PM
paid4c4
General Topics/Tech Tips
Feb 16, 2016 07:45 PM
SeniorChief56
Feb 15, 2014 06:44 PM
lumberjacker
May 20, 2010 06:14 AM
