O ring that goes on drain bolt.
Old Nov 7, 2010 | 08:57 AM
Striker951's Avatar
Striker951
Originally Posted by Mr. Lucky
The correct O-ring size is #41 (9/16" OD x 7/16" ID), available at any hardware store. All the fluid plugs use the same size.
On the Heritage, the primary o-ring is smaller.
Old Nov 7, 2010 | 10:43 AM
RHillbilly's Avatar
RHillbilly
my 09 Fatboy takes the #8 orings I have been running the ones from home depot no problem
Old Nov 7, 2010 | 10:56 AM
Soft06's Avatar
Soft06
[quote=Mr. Lucky;7499659]The correct O-ring size is #41 (9/16" OD x 7/16" ID), available at any hardware store. All the fluid plugs use the same size.[/quote]
My Primary drain plug O ring is smaller than my Trans and my Oil drain plug O-rings...
Old Nov 7, 2010 | 04:37 PM
wb0zrd's Avatar
wb0zrd
I'm suppose to change my oil?
Paul in Colorado
Old Nov 7, 2010 | 05:22 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Default Primary
[quote=Soft06;7505017]
The primary on some 04's like mine are tapered pipe plug dry seal designed to not require Teflon tape or a sealer (nptf). The 9/16 x 7/16 standard o-ring at the dealer is black buna-n designed for oil for the transmission and oil. Any standard black o-ring from the auto-parts stores will be buna-n. The bolt it fits on and screws into is an ms fitting. The o-ring is actual going up into a angle seat. If this fitting has not been damaged you should use a new o-ring at least ever other time and not use sealer. The fitting is deigned for the washer face of the bolt to go metal to metal with the fitting so as to stay tight. Remember, a standard 9/16x7/16 o-ring is .07 diameter cross section. Also does no harm in using sealer on nptf. Unless you have measuring tools it would be best to get it from Harley dealer in my opinion. FP, do not use an o-ring that is tool large. It will not go down into taper and tend to act more like a flat seal and unless you use a sealer on threads the bolt just may leak or worst yet vibrate out.
Old Nov 7, 2010 | 05:34 PM
Faast Ed's Avatar
Faast Ed
[quote=grf000;7506247]
"Don't require teflon" doesn't mean you can't benefit from it.
One benny is that you can go soft on the torque without worrying about it coming loose (teflon paste, not tape). Tapered threads when overtightened can ruin your day.
As I said earlier, my o-ring has to be worn to the point of falling off, before I even bother replacing it. The teflon is doing the work on my bike, and all my cars. Many years have gone by without issue.
Old Dec 15, 2014 | 06:40 PM
dp1's Avatar
dp1
Which teflon paste do you all use on threads?
Old Dec 15, 2014 | 06:49 PM
soft 02's Avatar
soft 02
Amazon.com: 4 Pack Permatex 80633 Thread Sealant with PTFE - 16 oz Can (14D): Automotive Amazon.com: 4 Pack Permatex 80633 Thread Sealant with PTFE - 16 oz Can (14D): Automotive
Old Dec 15, 2014 | 07:54 PM
tmilo1000's Avatar
tmilo1000
Non HD o rings will void the warranty.
Old Dec 16, 2014 | 08:02 AM
oct1949's Avatar
oct1949
last ones I got from the dealer was $.50cent per...
then I found these,, and they store is a 1/2 mile from the house..
about $4.00 per 100 with tax... I keep 50 and gave the Son the other 50...
https://www.fastenal.com/web/products/details/1166807
