Front end wooooooooble
Old Nov 23, 2010 | 07:43 PM
coronerrpm's Avatar
coronerrpm
Default Front end wooooooooble
All I have done to the ride was swap out factory bars to HD Street Slammers but since then my front end is wobbleing out of control. I did NOT swap the cables that should be shorter and wondering if the excess is putting pressure on the front end making it go crazy? Never had a problem until the bar swap. I know my break line is to long and most likely the others but can/will this cause head shake??? I am really stumped on this one. I am thinking the extra length is adding pressure to the front but not 100% sure. As I said this is all I did. Anyone????
Old Nov 23, 2010 | 07:54 PM
Santo's Avatar
Santo
I dont think its your cables, I switched out my risers awhile back and my cables where long and I didnt have a problem with wobble. Check yout tire presure, retorq everything down. Im sure its a simple fix.
Old Nov 23, 2010 | 07:57 PM
coronerrpm's Avatar
coronerrpm
Thanks but the tire pressure is right on and everything (the riser bolts) and so are also bang on. I do not get stumped often but this one has me by the ba**s!
Old Nov 23, 2010 | 08:06 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Steering head bearing? That is all that is left. Tighten that bad boy up...
Drew
Old Nov 23, 2010 | 08:19 PM
coronerrpm's Avatar
coronerrpm
OK I will check it in the am but this makes Noooo sense. The thing ran/rode like a charm before but now it feels totally unsafe! I can't put my fingure on this one.
Old Nov 23, 2010 | 08:26 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Are your riser bolts nice and tight? 3/4" deep socket should allow you to get to them with a short extension.
Drew
Old Nov 23, 2010 | 09:18 PM
coronerrpm's Avatar
coronerrpm
Just in from the garage. Checked the riser bolts and all are spot on! This thing rode like a charm before the bar change but now::::
It feels like if I turn right I am fighting the bike the whole time. I am thinking the cables/break line as they are around 2 to 3" to long. I did not put a tape to them so that is only a juess but something is not right. It is like going from a Caddie to a VW bug with a bad stearing problem.... .
Old Nov 23, 2010 | 10:17 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
I know the 07 fatboy's had issues with the front wheels as a friend just went through this, but by 2010 this was long since fixed. I think you otter take it in for "warranty" work.
Drew
Old Nov 29, 2010 | 08:37 PM
BerettaMan's Avatar
BerettaMan
Talking
Check neck bearings, tire pressure, balance, alignment.
Old Nov 29, 2010 | 09:11 PM
RocketRocker's Avatar
RocketRocker
Im no expert but maybe the problem is with the riser bushings? If so, it would cause some probs like your describing. I would also as a precautionary measure replace the grade 8 bolts while your at it.
