HELP - with newly purchased Harley
Old Dec 3, 2010 | 08:35 PM
lschantz1's Avatar
lschantz1
Default HELP - with newly purchased Harley
I just purchase a 2007 FXSTC. 2300 miles on it. It came V&H pipes, SE air cleaner, SE plugs and wires and PCIII tuner. the right map for the upgrades is loaded in the tuner (checked it myself)
The plugs are black and sooty looking as is the inside of the exsaust.
it seems to idle fine but has an occational hesitation if you open the throttle. it doesn't seem to matter if you open it slow or crack it it still has the occational miss/hesitation.
I checked the plugs ant they are the correct part number. I've only put about 40 miles on her so I don't think the plugs would have fouled that bad since i've owned it (two weeks)
it seems to run fine otherwise but the plug fouling concerns me. this is my fiest bike in 17 years so I don't have a lot of rescent memories to compare to as far as the performance goes but it does seem okay.
I rode for many years when I was younger but sold my last bike in 1993.
700cc 4cyl rice popper.
any help would be greatly appreciated.
Old Dec 3, 2010 | 09:32 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
It sounds like the map you have is a bit rich.
Drew
Old Dec 3, 2010 | 09:45 PM
av8or's Avatar
av8or
I agree with Drew. The plugs should be more of a coffee color. I would try a different map.
Old Dec 3, 2010 | 09:47 PM
lschantz1's Avatar
lschantz1
I was planning on a dyno tune in the spring. Its too cold and too much snow to ride anymore this year. going to winterize it tomorrow.
The local shop is an authorized Dyno Jet facility.
Do you think this will eliminate the problem or should I just call DJ and ask for a slightly leaner Map with my upgrades? Thanks!
Old Dec 3, 2010 | 10:30 PM
mke125125's Avatar
mke125125
like the good dr. said. the map aint right. find a reputable dyno guy and he should fix you right up.
Old Dec 4, 2010 | 06:31 PM
hdfreed's Avatar
hdfreed
Stage III
The map might be right but you can manually adjust the power commander to enrich or lean it out with the buttons. It might have been manually enriched before.Go to the PC website and find out how.
Old Dec 4, 2010 | 06:51 PM
beaureed445's Avatar
beaureed445
Get that thing on the drum for a tune as soon as you can. As already said (multiple times), you map is too rich. This is common with canned maps.
gilbert_roadking
19
May 16, 2016 08:16 AM
jackinthebox
Exhaust System Topics
Apr 12, 2011 02:42 PM
UH60Hwkdrvr
Mar 20, 2008 12:13 PM
Viejo
Feb 26, 2007 04:41 PM
Stel67
Aug 9, 2006 04:34 PM
