True Dual installation
Old Jan 13, 2011 | 12:28 PM
creatv1's Avatar
creatv1
Default True Dual installation
I'm putting on my Samsons today, and wondering if you guys would recommend some sort of sealer between the various connections. Something like copper RTV sealant? Or am I good with just the clamps.
Also, should I put anything on the studs on the jugs? Anti-seize or loctite?
Thanks for your help!
Old Jan 13, 2011 | 12:30 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Ultra Copper. I never put anything on the engine studs, just the nut.
Drew
Old Jan 13, 2011 | 12:31 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
I've never used a sealant, and have had no issues. The antiseize couldn't hurt though
Old Jan 13, 2011 | 04:03 PM
shineybike's Avatar
shineybike
I used ultra copper on the muffler to head pipe joints to cure small leaks and it worked fine.
Old Jan 13, 2011 | 07:58 PM
SMF's Avatar
SMF
I always use anti seize on studs with heat because they get warped by getting hot and cold all the time
Old Jan 13, 2011 | 09:03 PM
CountryD's Avatar
CountryD
+1 on the ultra copper, you can find it at wally world
Old Jan 13, 2011 | 09:06 PM
Iceman24's Avatar
Iceman24
Recommend high-temp silicone on pipe/header joint(s) & double-nut the cyl/flange studs. Don't want any air leaks w/exhaust...
Old Jan 13, 2011 | 09:23 PM
HOGDAT's Avatar
HOGDAT
Rinehart recommends using a sealent on the head-pipe to muffler joint.
Old Jan 14, 2011 | 02:21 AM
JayDee5150's Avatar
JayDee5150
+1 for ultra copper...
Works great...seals like a glove. Best of all, it doesn't lock anything together so if you need to disassemble the exhaust in the future, it will break down fairly easily.
Old Jan 14, 2011 | 08:02 PM
nikonf8's Avatar
nikonf8
Default Pipes
High temp silicone
Garrman
Exhaust System Topics
16
Jan 2, 2018 05:19 AM
Ozzy61
Mar 18, 2013 08:52 PM
WARG
Mar 8, 2011 08:26 PM
Ultrasweet
Aug 9, 2008 12:08 AM
smathisen
Sep 21, 2007 01:32 PM
