Dark Custom Blackline
Old Jan 21, 2011 | 10:57 AM
TattedUp's Avatar
TattedUp
I read it is a stripped down bare bones Softail. I can't seem to find a kick start though. Not a bad lookin bike but I do like the crossbones more. Just my 2 cents.
Old Jan 21, 2011 | 11:39 AM
HellrideMFG's Avatar
HellrideMFG
I like it...
Old Jan 21, 2011 | 11:51 AM
TW's Avatar
TW
Originally Posted by hspring03
What's the over/Under on how many "Blackline" threads will be started today?.. lol
I say 5.
I started one yesterday and now see 2 more this morning.
Old Jan 21, 2011 | 11:52 AM
hksigman's Avatar
hksigman
looks to me like the "new an improved" Night Train...
Old Jan 21, 2011 | 12:23 PM
JY Kelly's Avatar
JY Kelly
Improved? How so?
And what is so "bad" about Softail suspension?
Old Jan 21, 2011 | 12:28 PM
Primo's Avatar
Primo
New Harley-DavidsonŽ Blackline™ is SoftailŽ stripped to the core
MILWAUKEE (January 21, 2011) -
Lean as wire, hard as iron and dark as a tar road at midnight, the new Blackline motorcycle is a Harley-Davidson Softail model pared to the bone. A rebellious creation of the Dark Custom movement, the Blackline celebrates three fundamental elements of motorcycling: mechanical beauty, internal combustion, and the long black line of the road ahead. www.harley-davidson.com.
The Blackline balances allegiance with rebellion, discarding previous conventions of color and chrome for a Dark Custom look that’s honest, functional and attainable. Visual elements of the original bobber movement are combined with the raw, hand-hewn style embraced by today’s young builders. The Blackline throws new fuel on a fire that burns across generations, an unquenchable desire to ride.
Lean and Tight
The rear fender is bobbed high-and-tight over a slim, 144mm tire that emphasizes an authentic hardtail profile. The compact headlight and speedometer are tucked low into the wide, FX front end, and there’s just enough shine to make the black parts look blacker. Black-rimmed laced wheels complete a look that’s tough, tempered and undeniably Harley-Davidson.
The styling spotlight shines on a Big Twin engine dressed in black and silver, and on a fuel tank shaved smooth and low. Aboard the Blackline, the rider hugs the frame on the lowest two-up seat ever offered by Harley-Davidson, and reaches high for new Split Drag™ handlebars that bolt right to the top triple-clamp.
The Softail chassis utilizes rear suspension control provided by coil-over shock absorbers mounted horizontally along the frame rails below the powertrain, where they are out of sight. So while the swingarm section replicates the lines of a vintage hardtail frame, the Blackline delivers suspension performance and handling that are thoroughly modern. The internally counter-balanced Twin Cam 96B ™ engine is rigid-mounted within the frame, creating a solid connection between rider and the power that moves the motorcycle to enhance the emotional experience of riding.
Key features of the 2011 Blackline include:
NEW Powertrain styling
Powertrain is finished in gloss black powdercoat on the rocker box covers, the crankcase, the outer primary cover, and the transmission side cover. The cylinders are silver powdercoat with machined highlights. The derby cover and timing covers are chromed.
Rigid-mounted, counter-balanced Twin Cam 96B™ V-Twin engine with Electronic Sequential Port Fuel Injection (ESPFI), rated at 89 ft. lbs. peak torque at 3250 rpm.
6-Speed Cruise DriveŽ Transmission.
NEW Round air cleaner cover in brilliant chrome.
NEW Black Denim powdercoat frame and swingarm.
NEW Profile Laced Aluminum wheels with black anodized rims. Front wheel is 21 x 2.15 inches; rear wheel is 16 x 3 inches. Dunlop Ž D402 tires are MH90-21 front and MU85B16 rear.
NEW FX front end with black powdercoat triple clamps and black painted fork lowers.
NEW Split Drag™ internally-wired handlebars mount directly to the top triple clamp.
NEW Asymmetric five-gallon Softail fuel tank is clean on the left side, with a low-profile fuel fill on the right. Die cast “Blackline” trim panel flowing down the center of the tank is just high enough to cover the fuel pump hardware.
NEW Analog speedometer on a triple-clamp mount that also holds indicator lights. LCD screen on the speedometer includes low-fuel warning and “miles to empty” display function.
NEW Bobbed rear fender with combination stop/tail/turn lights in black housings, and a new composite license plate holder and light module that mounts on the lower edge of the fender.
NEW Raw forged rear fender supports are finished in Black Denim powdercoat.
NEW One-piece, two-up seat and passenger pillion. Laden rider seat height is 24 inches, the lowest two-up seat offered by Harley-Davidson. Gap between the nose of seat and fuel tank exposes the top of the frame.
NEW 5.75-inch diameter headlamp in gloss black shell.
Polished forward foot controls.
Over/under chrome shotgun exhaust.
Optional Security Package with Anti-lock Braking System and Smart Security System
Old Jan 21, 2011 | 12:32 PM
07Fatty's Avatar
07Fatty
For the price it should be a 103ci, it seems they have figured out how to make a bike almost blacked out lacking $1000 worth of black parts to be bought in upgrades like the low
Old Jan 21, 2011 | 12:33 PM
gr495's Avatar
gr495
Stage IV
I like the way it looks could use a black exhaust and a side mounted license plate.
Old Jan 21, 2011 | 12:34 PM
wiseguy2day's Avatar
wiseguy2day
klf33 i called Joker about the softail gauge setup just like the sporty one. They said they get a lot of inquiries but they haven't made one yet.
Old Jan 21, 2011 | 12:45 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
There's already one thread about this in this forum. Lockola.
Figjam
May 7, 2017 03:13 AM
DougYITBOS
Nov 19, 2012 02:01 PM
5litrebeater
Sep 15, 2011 09:08 AM
Shadow_otw
Sep 13, 2011 08:07 AM
Krazy8s
Jul 14, 2010 12:05 AM
