Rear Strut Question (Fatboy)
Old Jan 22, 2011 | 12:24 PM
Nubs13's Avatar
Nubs13
Default Rear Strut Question (Fatboy)
Does anyon know where I can get a set of rear struts without the holes for the turn signals for a 2010 fatboy? What years can be used?
Thanks
Old Jan 22, 2011 | 01:49 PM
Big H's Avatar
Big H
I have not seen struts without the turn signal holes alone. There are struts that are completely smooth. Can you use those or do you have a need for the external hardware (backrest, bags, etc...)? I would believe the smooth struts could be drilled for normal hardware and then exclude the turn signal hole.
Old Jan 22, 2011 | 02:30 PM
Dirty Fxstd's Avatar
Dirty Fxstd
I would try ebay
Old Jan 22, 2011 | 03:53 PM
Daddy-O's Avatar
Daddy-O
HD has chrome plugs that fit them. They use them on the Deluxe. Parts guy should be able to look it up for you if you wanted to go that way. I did it on my FB and it looks pretty clean.
Old Jan 22, 2011 | 05:29 PM
Dustmaker's Avatar
Dustmaker
As Daddy-O says....all of the Heritages and Deluxes have these.
As for the smoothies.....they have bolts welded to them from the inside....would be almost impossible to drill holes in them for back rest.
Jimmy
Old Jan 22, 2011 | 09:57 PM
Daddy-O's Avatar
Daddy-O
If you need them, the part numbers for the plugs are:
Item, Name, Quantity, Price, Total
53830-00, HOLE PLUG, CHROME, 2, $1.49, $2.98
68446-00, BUTTON PLUG, 2, $.99, $1.98
Might want to double check those p/n's just to be safe.
Who says everything from HD costs a hundred dollars?
Old Jan 23, 2011 | 05:35 AM
Nubs13's Avatar
Nubs13
Thanks everyone....
Old Jan 23, 2011 | 05:36 AM
Nubs13's Avatar
Nubs13
Ill call up the local HD tomorrow Daddy-O
Thanks
TimzFatboy
Nov 17, 2015 07:14 AM
Nubs13
Aug 29, 2010 04:59 PM
goblish
Nov 14, 2009 11:01 PM
Newgene
Jul 7, 2009 09:15 PM
budiii3
May 15, 2007 01:20 AM
