i switched from a metric to a harley and this kinda bugs me when you would go on a metric board and ask a question you would usually get several decent answers to help you fix your problem. But alot of times i read on here where someone asks a simple question and the smart**ses come out and say its in the manual. I have a manual for mine and i would be more than happy to give folks information. After all thats what this board is for to help people. Is it me or are the harley riders stuck up or something. I sure hope I dont get that way!!
if i was home i would go help him out. not being stuck up, just offering some help
clutch diaphragm spring 90-110 in lbs
clutch hub nut 70-80 ft lbs left hand loctite 262
comp nut 150-165 ft lbs loctite 262
inner pri to engine 17-21 ft lbs bend tabs
pri cover screws 108-120 in lbs
inspection cover short 84-108 in lbs
pri to trans 17-21 ft lbs bend tabs
trans lockplate screws 84-108 in lbs loctite patch use 3-5 times
trans sprocket nut 50 ft lbs.left hand loctite 262
hope this helps...steve
this is from a 2000 service manual. should be the same.
Reason: added info
I just think that some are a little to sensitive about, "its in the manual"- is not offensive but rather someone looking out for someone...because without it you could end up like me (overtightening and popping threads off) before I got one.
