timing cover help...
Old Feb 12, 2011 | 07:20 AM
fatrob74's Avatar
fatrob74
Default timing cover help...
i bought one of the dark custom timing covers. it is a lot thicker than the factory stamped sheet metal cover. i went to put the screws back in and barley tightened them and they all three started to strip out.
the new cover didnt come with longer screws. is there a harley part number for the longer screws i would need to install it?
thanks,
rob
Old Feb 12, 2011 | 07:45 AM
lionsqrne's Avatar
lionsqrne
I would just go to the hardware store. Your gonna pay less anyway. Have them match the size up in chrome and give you a lengthened one then.
Old Feb 12, 2011 | 07:57 AM
watchluvr4ever's Avatar
watchluvr4ever
Go figure, I've owned a few different HD timer covers and never had this problem myself and I've always used the stock screws.
Old Feb 12, 2011 | 08:17 AM
RANGER73's Avatar
RANGER73
Just swapped mine, (older bike) only had 2 screws. New cover came with the screws and new gasket. I had 2 covers, top cover was decorative (live to ride) was riveted in at 12-6 positions to second plate, second plate had screws at 3-9 positions. removed these, plate and gasket, and installed new gasket and cover. The screws were about 3/8" long. I'd go with stainless, and a dab of blue thead lock.
Old Feb 12, 2011 | 08:20 AM
fatrob74's Avatar
fatrob74
ill have to look tonight..but i dont think mine even had a gasket?
Old Feb 12, 2011 | 09:14 AM
stevevfd's Avatar
stevevfd
Twin cam motors don't have a gasket. It's just a decorative piece and doesn't actually get exposed to oil or the inner workings of the motor.
Old Feb 12, 2011 | 10:41 AM
hdgzr's Avatar
hdgzr
...i went to put the screws back in and barley tightened them and they all three started to strip out...
I did the same thing on the first one I installed on my '99 FXDX. I found a bottom-hole tap, gently ran in in, then applied a dab of silicone to the screw and reinstalled...being careful to not over-tighten. Worked like a charm.
Old Feb 12, 2011 | 10:45 AM
WFA's Avatar
WFA
Originally Posted by lionsqrne
i would just go to the hardware store. Your gonna pay less anyway. Have them match the size up in chrome and give you a lengthened one then.
Hardware store may have chrome if not stainless steel will do. Just add a little polish to the head. Actually mine had a phillips head. Worked great and still in place. No gasket needed.
WOODY
Old Feb 13, 2011 | 09:06 AM
RANGER73's Avatar
RANGER73
Gasket came with new cover, assumed was to keep out road dust and water.
Old Feb 13, 2011 | 09:09 AM
Faast Ed's Avatar
Faast Ed
I only bought one in recent years, and it came with longer screws.
Even had a dab of locktight already on them.
Ace hardware would be my first choice.
