Shock socket size?
Old Mar 5, 2011 | 07:14 AM
KeeBee's Avatar
KeeBee
Default Shock socket size?
I thought I had a pretty good set of tools but didn't have a socket big enough for the two bolts that hold each shock in. The nuts closer to the front of the bike is 11/16. Guessing the bolts are 13/16? I need to buy a mechanics set of tools at some point.
So far my mods are going pretty good. Bike is really easy to work on so far.
Old Mar 5, 2011 | 08:36 AM
jimmers1817's Avatar
jimmers1817
Mine are closer to 17mm for the front and 19mm for the rear. Don't recall exactly what I used when I pulled mine but I do recall needing a breaker bar to break the rear bolts.
There's alot more to the process than at first appears. I did a search and found various posts and recommendations on it. Plus I have the service manual.
Sorry I don't recall exactly what steps I had to do. But I will say it involved both jacking the bike up and putting it on a stand. Concrete block on the front frame and a car jack stand at the swingarm pivot area on the rear. There was also a point where I had to put a jack under the rear wheel to lift up the wheel a tad to get the shocks in. In my case I was putting Deluxe shocks on my Heritage to drop it an inch.
Try a search and you may get more detailed info. I think I got my best hits under "lowering a softail".
Good luck
Old Mar 5, 2011 | 08:43 AM
KeeBee's Avatar
KeeBee
Thx, I was searching for Shotgun shock install.
Old Mar 5, 2011 | 08:44 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
The front bolts are 3/4 and the rear are 11/16. If you still have stock bolts in heat them with a hair dryer or heat gun to soften the loc tite.
Drew
13bob
Sep 10, 2014 07:21 PM
kiwideuce
Jul 4, 2013 12:45 AM
billvaughn
Jul 21, 2012 07:26 AM
07bobber
Mar 29, 2008 11:18 AM
JohnnyBoy
Mar 11, 2008 07:54 PM
