Stalling at stop lights and such...
Old Mar 11, 2011 | 05:53 PM
Northside's Avatar
Northside
Originally Posted by DR. V-TWIN
That is a good thought. I jsut replaced the CPS and that was not it. Unattached my power commander and that was not it. I guess I'll just hope my speedo is done soon and pray that is it. I am about to double check the routing on the cables under the tank. Waiting for the bike to cool off. I am not buying any more sesnors until I put teh speedo back on and see what happens. This is driving me crazy here and to think it might be something so simple.
Drew
Drew, think about it, properly adjusted the cables need about an 1/8 inch of slack, or free play, where the cable is not opening the throttle plate at all, and it should still idle. It should start and idle with no throttle cable at all. If it was idling fast, or reving when your turn the bars it could be the cable adjustment or routing, but the cables can't make it idle too slow. The idle speed is controlled by the ECM. The speedo sends information to the ECM. What I'm saying is, it ain't the cable causing it to die.
Old Mar 11, 2011 | 07:42 PM
Harlie Rider's Avatar
Harlie Rider
Smile
Drew, my StreetBob did this twice, both times were when the country was having a gas problem like we are having now.
When I ran premium gas, the bike ran fine, if I ran regular gas, the bike would die when I pulled up to a traffic light or stop sign. Some stations around here were putting regular gas in their premium tanks, so when you bought what you thought was premium, it was regular grade.
Once I had a problem like yours on my '08 Heritage. Turned out to be regular grade gas in the premium tanks.
I hope this simple suggestion helps.
Old Mar 11, 2011 | 08:03 PM
DyNaBoB's Avatar
DyNaBoB
drew, did you check to see if its throwing codes???
Old Mar 11, 2011 | 08:08 PM
DyNaBoB's Avatar
DyNaBoB
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted)
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
Also if the code set is a historic code (not a constant light) after 50 start and run cycles of at least 30 seconds each in duration, the light will extinguish itself as long as the error hasn't occurred again.
If it were a current code, the light would remain lit while running.
DTC FAULT CONDITION MODULE
"BUS Er" Serial data bus shorted/low/open/high
B0563 Battery Voltage High TSM/TSSM
B1004 Fuel Level Sending Unit Low Instruments
B1005 Fuel Level Sending Unit High/Open Instruments
B1006 Accessory Line Over voltage Instruments
B1007 Ignition Line Over voltage Instruments
B1008 Reset Switch Closed Instruments
B1122 Right turn output fault
B1125 (HFSM) Left Turn Output Short to Battery.
B1131 Alarm Output Low TSM/TSSM
B1132 Alarm Output High TSM/TSSM
B1134 Starter Output High TSM/TSSM
B1135 Accelerometer Fault TSM/TSSM
B1141 Ignition switch open/low
B1151 Sidecar BAS Low TSM/TSSM
B1152 Sidecar BAS High TSM/TSSM
B1153 Sidecar BAS Out of Range TSM/TSSM
P0106 MAP Sensor Rate of Range Error Carb
P0107 Map Sensor Failed Open/Low Carb
P0107 Map Sensor Open/Low EFI
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High EFI
P0112 IAT Sensor Voltage Low EFI
P0113 IAT Sensor Voltage Open/High EFI
P0117 ET Sensor Voltage Low EFI
P0118 ET Sensor Voltage Open/High EFI
P0122 TP Sensor Open/Low EFI
P0123 TP Sensor High EFI
P0131 Front 02 sensor low (lean)
P0132 Engine running rich
P0134 Front 02 sensor open/not responding
P0151 Rear 02 sensor low (lean)
P0152 Rear 02 sensor high (rich)
P0154 Rear 02 sensor open/not responding
P0261 Front Injector Open/Low EFI
P0262 Front Injector High EFI
P0263 Rear Injector Open/Low EFI
P0264 Rear Injector High EFI
P0373 CKP Sensor Intermittent Carb
P0373 CKP Sensor Intermittent EFI
P0374 CKP Sensor Not Detected Carb
P0374 CKP Sensor Sync Error EFI
P0501 VSS Low Carb
P0501 VSS Low EFI
P0502 VSS High/Open Carb
P0502 VSS High/Open EFI
P0505 Loss of Idle Speed Control EFI
P0562 Battery Voltage Low Carb
P0562 Battery Voltage Low EFI
P0563 Battery Voltage High Carb
P0563 Battery Voltage High EFI
P0602 Calibration Memory Error Carb
P0603 EEPROM Failure Carb
P0603 ECM EEPROM Error EFI
P0604 RAM Failure Carb
P0605 Program Memory Error Carb
P0605 ECM Flash Error EFI
P0607 Converter Error Carb
P0661 Intake solenoid low/open
P0662 Intake solenoid high/shorted
P1001 System Relay Coil Open/Low EFI
P1002 System relay Coil High/Shorted EFI
P1003 System relay Contacts Open EFI
P1004 System Relay Contacts Closed EFI
P1009 Incorrect Password Carb
P1009 Incorrect Password EFI
P1010 Missing Password Carb
P1010 Missing Password EFI
P1351 Front Ignition Open/Low Carb
P1351 Front Ignition Open/Low EFI
P1352 Front Ignition Coil High/Shorted Carb
P1352 Front Ignition Coil High/Shorted EFI
P1353 Front Cylinder No Combustion EFI
P1354 Rear Ignition Coil Open/Low Carb
P1354 Rear Ignition Coil Open/Low EFI
P1355 Rear Ignition Coil High/Shorted Carb
P1355 Rear Ignition Coil High/Shorted EFI
P1356 Rear Cylinder No Combustion EFI
P1357 Intermittent Secondary Front EFI
P1358 Intermittent Secondary Rear EFI
U1016 Loss of ICM/ECM Serial Data Instruments
U1016 Loss of ECM Serial Data, Vehicle Speed, Vehicle Inhibit Motion or Power train Security Status TSM/TSSM
U1064 Loss of TSM/TSSM Serial Data Carb
U1064 Loss of TSM/TSSM Serial Data EFI
U1064 Loss of TSM/TSSM Serial Data Instruments
U1097 Loss of Speedometer Serial data Carb
U1097 Loss of Speedometer Serial data EFI
U1097 Loss of Speedometer Serial data TSM/TSSM
U1255 Missing Message at Speedometer EFI
U1255 Serial Data Error/Missing Message EFI
U1255 Serial Data Error/Missing Message Instruments
U1255 Serial Data Error/Missing Message TSM/TSSM
U1300 Serial Data Low Carb
U1300 Serial Data Low EFI
U1300 Serial Data Low Instruments
U1300 Serial Data Low TSM/TSSM.
U1301 Serial Data Open/High Carb
U1301 Serial Data Open/High EFI
U1301 Serial Data Open/High Instruments
U1301 Serial Data Open/High TSM/TSSM
2006 models with 02 sensors (Dynas)
P0131 Front 02 sensor lean for any length of time
P0151 Rear 02 sensor lean for any length of time
Above codes can also be set if 02 sensor fails.
DyNaBoB's Avatar
DyNaBoB
then you can see if its a sensor or not
Old Mar 11, 2011 | 08:12 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Well my speedo is at the shop being modded which is m,sot likely the cause of this entire situation. I knew it couldn't really be the cables anyway, but i double checked as that was the last thing I did to the bike. I disconnected teh battery for 5 mintues to let the ecm reset itself and it sill acts the same. I want my speedo back so I know if that is the issue or not, but until then it will be ridden as is. I have a 300 mile ride planned for Sunday. The funny thing is this is really the first issue of this sort i have had since 2005.
Drew
Old Mar 11, 2011 | 08:14 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
I started a second thread in general as i would appreciate more exposure on this subject of my bike not running properly and it has been locked. Sorry I broke the rules IZZO, just trying to get my situation sorted out and the more people see the thread the more responses I will get. I am sure you understand.
Drew
Old Mar 11, 2011 | 08:15 PM
DyNaBoB's Avatar
DyNaBoB
hmmm....i think thers guys on here that ditched ther speedo all together but i might be mistaken and they have a carb.......
Old Mar 11, 2011 | 08:27 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Yeah. I don't know. I am thinking about replacing the Throttle position sensor next, and then the idle air control, but at $50-$75 a pop this si getting expensive for something might have no result. So I will try to hold out until my speedo is done and see what that does.
Drew
Old Mar 11, 2011 | 08:44 PM
DyNaBoB's Avatar
DyNaBoB
get your speedo back and run the test and see if its a sensor code...it will tell you wut is wrong so you dont have to trouble shoot
