advice needed?
Old Mar 11, 2011 | 05:25 AM
bobbyjoes's Avatar
bobbyjoes
Default advice needed?
advice needed? Hi ,i am chaging my primary gear from 25/36 to 24/37, i orderd the 24 tooth and 37846-99a clutch basket shell from zanotti,if you look at my signature, while i have it off would you do anything with the clutch,bike has 30 thosand miles on it ,change disc?better clutch ,not familiar with clutch stuff ,money is a factor ,thanks for the help as always
__________________
2004 heritage classic/i
95 build
SE flat top pistons
Andrews chain conversion
Big Boyz street port(83cc)
Fatcat 2:1
Andrews 37n cam
Smith bro quick install
Tunned by BVBOB
Old Mar 11, 2011 | 06:30 AM
Mike T's Avatar
Mike T
__________________
95 build
SE flat top pistons
Fatcat 2:1
Andrews 37n cam
Tunned by BVBOB
Just leave the clutches alone would be my suggestion. I have over 100k on the same clutch pack.
Old Mar 11, 2011 | 07:13 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
You might drop in a SE clutch diaphram. Not that expensive and beefs up the holding power of the clutch.
Old Mar 11, 2011 | 11:29 AM
bobbyjoes's Avatar
bobbyjoes
thanks so far for the advice,appreciate it
HardLuck71
Aug 18, 2017 04:47 PM
2013_FLHTK
Jun 3, 2017 03:59 PM
XFXDX
Mar 20, 2015 07:42 AM
Rabbs00
May 15, 2011 08:11 PM
Born2cure
Nov 21, 2009 08:37 AM
