Check Engine light,....
Old Oct 13, 2006 | 01:31 AM
Saint666's Avatar
Saint666
Default Check Engine light,....
Few times this week ,.,,just for 3 to 5 secs the yellow enigne turned on while i was riding.
I thought maybe ite the hypercharger or somehting related with the efi,...
It did it just a few times and went off ,.....
Should i care?...
I was told that if it goes off ,,not to worry,,
what u guys think?
Old Oct 13, 2006 | 01:41 AM
Josey Wales's Avatar
Josey Wales
Default RE: Check Engine light,....
Check it out!
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
DTC FAULT CONDITION MODULE
B0563 Battery Voltage High TSM/TSSM
B1004 Fuel Level Sending Unit Low Instruments
B1005 Fuel Level Sending Unit High/Open Instruments
B1006 Accessory Line Overvoltage Instruments
B1007 Ignition Line Overvoltage Instruments
B1008 Reset Switch Closed Instruments
B1131 Alarm Output Low TSM/TSSM
B1132 Alarm Output High TSM/TSSM
B1134 Starter Output High TSM/TSSM
B1135 Accelerometer Fault TSM/TSSM
B1151 Sidecar BAS Low TSM/TSSM
B1152 Sidecar BAS High TSM/TSSM
B1153 Sidecar BAS Out of Range TSM/TSSM
P0106 MAP Sensor Rate of Range Error Carb
P0107 Map Sensor Failed Open/Low Carb
P0107 Map Sensor Open/Low EFI
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High EFI
P0112 IAT Sensor Voltage Low EFI
P0113 IAT Sensor Voltage Open/High EFI
P0117 ET Sensor Voltage Low EFI
P0118 ET Sensor Voltage Open/High EFI
P0122 TP Sensor Open/Low EFI
P0123 TP Sensor High EFI
P0261 Front Injector Open/Low EFI
P0262 Front Injector High EFI
P0263 Rear Injector Open/Low EFI
P0264 Rear Injector High EFI
P0373 CKP Sensor Intermittent Carb
P0373 CKP Sensor Intermittent EFI
P0374 CKP Sensor Not Detected Carb
P0374 CKP Sensor Synch Error EFI
P0501 VSS Low Carb
P0501 VSS Low EFI
P0502 VSS High/Open Carb
P0502 VSS High/Open EFI
P0505 Loss of Idle Sped Control EFI
P0562 Battery Voltage Low Carb
P0562 Battery Voltage Low EFI
P0563 Battery Voltage High Carb
P0563 Battery Voltage High EFI
P0602 Calibration Memory Error Carb
P0603 EEPROM Failure Carb
P0603 ECM EEPROM Error EFI
P0604 RAM Failure Carb
P0605 Program Memory Error Carb
P0605 ECM Flash Error EFI
P0607 Converte
Old Oct 13, 2006 | 02:19 AM
Saint666's Avatar
Saint666
[sm=boink3.gif] To tell u the truth ,,Your info it too much for my brain!!!heheheheheheh
Just wanted to know if someone went thru something like i did...
But THANK YOU !
Old Oct 13, 2006 | 02:45 AM
bikerbehaviorist's Avatar
bikerbehaviorist
Hey Josey Wales That is cool - I just printed that and put it in my service manual - thanks
Old Oct 13, 2006 | 03:27 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Thank you Josey Wales I printed it out too. Its probably in my service manual someplace, but its easier to use a printout like that than a big book.
Now i'm going to copy it into a word file and save it on the hard disk, CD too maybe, just in case.
Old Apr 22, 2007 | 11:42 AM
Tweak's Avatar
Tweak
Stage I
Default RE: Bike Quits - Code B1006
Have 2004 EFI Deuce with code B1006
Bike is quitting all the time - But can restart... run a mile or two, quits again.
Never see any other issues with it... cleaned battery and cables - battery full charged.
Also noticing... lose`s all electrical power too. Can restart most the time to get home..,
but just keeps quitting. Sometimes you can ride 10 miles., an smetimes you can ride only 1 or 2 miles and it quits.
Is there possibly a ECU or a circut breaker issue we`re having here...????
Thanks for any help you guyz can offer
tweak
Old Apr 22, 2007 | 02:40 PM
DaveJ's Avatar
DaveJ
JW, that is awesome!!! I am printing it as well.
[align=left] [/align]
Old Apr 22, 2007 | 03:27 PM
DMJFatboy's Avatar
DMJFatboy
Thanks, me to
Old Apr 22, 2007 | 03:35 PM
anubisss's Avatar
anubisss
Thnaks for the info. I jsut saved it in word. I'll print it when my printer works again...[:@]
Old Apr 23, 2007 | 05:53 PM
inferno_md's Avatar
inferno_md
Thanks for the instructions and codes, I have printed and saved as well.
