project complete, got qyestions
Old Mar 15, 2011 | 11:45 AM
DeluxeW00kie's Avatar
DeluxeW00kie
Default project complete, got qyestions
so, the digital tach/analog speedo came in last night, plugged it in, filled the tank , no gas light issues. looks great!! ill post pics up later of tbe bike. had a question tho. the upper nut on the rear header flange keeps coming loose. i have to snug it down before every ride. its a pita, any ideas on this? btw, im running a samson true dual ( sounds awesome btw, love it!!) thks for the ideas. pics to follow with list of mods later.
Old Mar 15, 2011 | 11:58 AM
Jaburg1's Avatar
Jaburg1
Can't wait to see the pics! Have you tried a little Loc-Tite on that nut?
Old Mar 16, 2011 | 12:01 AM
DeluxeW00kie
hmm.... not sure if loctite would be a good idea on a nut to stud combo. any other suggestions guys?
Old Mar 16, 2011 | 12:10 AM
soft 02's Avatar
soft 02
Crimp nut and anti-seize.
Old Mar 16, 2011 | 12:11 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
that is strange as a softail has a rigid mounted engine meaning that it does not shake like the rubber mounted engines do. Are you sure youa veh tightened it down all the way? I think loctite is useless as the heat will negate its effect, but that is just what i think.
Drew
Old Mar 16, 2011 | 12:18 AM
soft 02's Avatar
soft 02
The stud could be streched either from age or being overtightened. If that's the case replacing the stud is the right fix but a quick fix is to use a crimp nut. That's my guess FWIW.
Old Mar 16, 2011 | 01:12 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
If you can't find any crimp nuts see if you can find a local aircraft mechanic who can get you a couple of nuts drilled for safety wire.
Alternatively you could try to find the drill guide to make your own.
The other option might be to find a couple of external tab lock washers.
Put one on under the nut, bend the tabs and it should keep the nut from coming loose on you.
SecondChance!!
May 20, 2010 07:17 PM
Jeremy8778
Mar 2, 2009 10:28 AM
XfasteddieX
Nov 6, 2007 08:32 AM
michelob
Jun 28, 2007 02:40 PM
wild wally
Jan 31, 2006 03:23 AM
