if your handlebars can be moved rather easily by pushing or pulling on the bars, you should consider changing to poly bushings. Get the $10.00 poly set from J&P, they work great. Throw a thick towel over the tank in case the bars slip. Just remove the bolts holding the risers to the tripple trees. It helps to have a buddy help.
to fix the bars not being straight, just loosen the riser clamp bolts a bit and adjust the bars by lining them up with the wheel. Make sure you don't let loose of them and scratch your tank.
Thanks for the advice guys, you have me made me feel a lot better about my new purchase I was thinking I'd bought a duff bike. I will try and straighten them later, and I'm going to order some bushes. cheers
Mines off too. It tracks just fine hell i've ridden miles with no hands on the bars, not a wobble,sway,veer or whatever.I've tried and tried loosening up everything up and retightening and mine still about 1/8 inch off...and its not the risrer bushing, because when I'm ridding on a smooth and straight the gap in the top trip/clamp is off from the little ridge spine on the frame on the back of the upper neck. And Ive even tried spinning front fork legs indiviually in the clamps just in case one has a slight bend.
My Deluxe front end dont look straight, the bike tracks great, no pulling to one side or anything like that, its just that when your going in a straight line the bars are ever so slightly out, and I mean only a little, a mate of mine couldnt even see it, but I know its there and its pissin me off.
The bars are not bent or anything so I dont know what it could be other than its not been put together right, there are no signs of it being dropped either.
Any ideas
Dude, you're the Lawn Mower Man, what do you expect? Your Deluxe is the most expensive two wheeled tractor you'll have. A little tweak and twist is required for any piece of gear.
All kidding aside you gotten a lot of good advice here, but don't get you hopes up, you may never get it perfect.
Usually the problem is the bars are crooked because of the rubber bushings. You can put your tire against the curb and tweek the bars till they are straight...but they are not likely to stay. If it bothers you that bad you can get some poly bushings or just ignore it.
+2 on that. My Train has always done the same thing.
+3 mine are crooked... noticed it the first time I rode it.... had to bring the bike home from the dealer in the back of my truck and I think when the straps were tightened down, it pulled the bars too much in one direction.. I was able to twist them almost straight by straddling the wheel between my legs and turning the bars as hard as I could.. still not perfectly straight but I don't care.. I've got new bars/risers/bushings coming from Dr. VTWIN as soon as they get them in stock.
