Ape Help
Old Mar 29, 2011 | 07:29 AM
TCannon22's Avatar
TCannon22
Default Ape Help
First off I will apologize, because I'm sure there has already been a ton of discussion on this. Right now I'm stuck with using my phone for Internet and it isn't search friendly.
I'm going from 10" baby apes to a set of 16" from Hill Country. My biggest questions are about bushings and mirrors. I know that the poly bushings are a good idea, but are they basically mandatory? My brother in law put 14" bars on his standard without swapping them and is issue free.
Also on the mirrors, do most people just flip their stockers upside down, leave them on top, or buy special mirrors to hang upside down? I'd really also like to see some mirror setups if you guys have pics, whether they are stock or custom.
Thanks!
Old Mar 29, 2011 | 07:33 AM
hspring03's Avatar
hspring03
Arlen Ness Rad II on 16"s upside down
Old Mar 29, 2011 | 10:55 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Poly bushings for sure. The amount leverage on taller bars is much greater than shorter bars and poly bushing will hold the bars steady as opposed to the stock rubber bushings which will leave a lot of slop. I would never run apes without poly bushings.
Drew
Old Mar 29, 2011 | 10:58 AM
fcsallan's Avatar
fcsallan
poly or just plain solid bushings on 16". Rubber will let those apes move 4" or so with a little pressure.
Old Mar 29, 2011 | 11:43 AM
Weevil's Avatar
Weevil
With 16" apes, go with the poly bushings. Stock bushings will be way to spongy.
Old Mar 29, 2011 | 11:55 AM
t stone's Avatar
t stone
quote=TCannon22;8114368]First off I will apologize, because I'm sure there has already been a ton of discussion on this. Right now I'm stuck with using my phone for Internet and it isn't search friendly.
Thanks![/quote]
Poly bushings are a must on 16s. I tried running the stock rubbers, to loose feeling. I run the mirrors on top. The only thing I could see with then under was my arms.
Stone
Old Mar 29, 2011 | 01:19 PM
JPL's Avatar
JPL
I run 16s w/ 2 inch risers right now and my mirrors are on top... I am upgrading to 17s with 3 inch risers so maybe I will try running them on the bottom... Lets see what happens!
Old Mar 29, 2011 | 04:05 PM
SanJuanRon's Avatar
SanJuanRon
Default Mirrors
I prefer the mirrors on top (but they look cool on the bottom). I have 17" Fly In Apes and 18" Wild I Chubby Physco Apes.....SJ Ron
Old Mar 29, 2011 | 05:44 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
My stock mirrors are under. You have to move your head a bit to see behind you, but it works for me. I always turn my head before changing lanes regardless.
Drew
Old Mar 29, 2011 | 07:19 PM
JPL's Avatar
JPL
Here is a picture. Bike is dirty as hell cause I have some problems with a screw...Waiting to fix that before I get it washed...
