Bars slipped while riding!
Brother ,that is a sweet looking bones
Drill and tap the riser and clamp and use set screws. I also cut two strips of drywall repair mesh and wraped around the bars where the clamps grip for the added grip. My bars have not even thought about moving since. This is the only thing that has been solid and I have tried all the tricks.
What you will need is a 5/16 Heli-Coil kit from Autozone. $20 or so. You will also need a 21/64 drill bit. It comes with instruction but I will try and give you a high level overview.
First you will drill out the existing threads with the 21/64 bit. Not all they way through the lower clamp but to the bottom of existing threads. (Easier than it sounds)
Second, you will re-thread the new holes with suplied tap.
Third, insert 5/16 heli-coil. I apply a bit of red lock tite to secure the coil. Once you screw the coil in. Lift the punch up a bit and give it a half turn. Then punch out the coil notch. (Again easier than it sounds)
Let it set for a bit.
During this time I apply the strips of drywall repair mesh around the bars. Only about a 1/2" strip that will hide under the clamp. This helps insure grip.
Finally, place bars back on and tighten down with existing allen bolts.
Should be good to go. Hope this helps brother.
This is similiar to the kit I got at AutoZone.
http://www.google.com/imgres?imgurl=...26tbs%3Disch:1
