Bars slipped while riding!
Old Apr 3, 2011 | 12:58 AM
SMF's Avatar
SMF
Looks like you bars weres tightened. Any apes require a tq check from time to time
Old Apr 7, 2011 | 03:04 PM
JRK5892's Avatar
JRK5892
use some small strips of emery cloth it will work great
Old Apr 7, 2011 | 10:16 PM
csc06ss's Avatar
csc06ss
I pinned my bars with roll pins or shire pins. It's a little bit more trouble to do, but I'll never have to worry about my bar moving again!
God bless!
Scott
Old Apr 7, 2011 | 10:27 PM
shooker's Avatar
shooker
Cut strips out of a couple of rubber gloves and rap them around the bars inside the risers.
Old Apr 7, 2011 | 11:10 PM
nikonf8's Avatar
nikonf8
Default Bars
Wow thats some crap. i would get that fixed ASAP
Old Apr 7, 2011 | 11:20 PM
NoRegerts's Avatar
NoRegerts
Thanks for all the advice. The new bars are on order but I'll be doing something to prevent this from ever happening again. As it is I tightened them and it hasn't happened since but I'm still freaking out waiting for it.
Old Apr 8, 2011 | 12:01 AM
csc06ss's Avatar
csc06ss
Are you replacing the bars because of this? If so, then just drill the cap and pin them. That will solve your problem without replacing the bars.
Scott
Old Apr 8, 2011 | 12:28 AM
NoRegerts's Avatar
NoRegerts
Scott
I'm replacing the bars because I don't care much for the bars. I'm fixing the issue because I never want this to happen again.
I'm thinking drilling the cap and pinning them would be the best fix though.
Old Apr 8, 2011 | 12:46 AM
csc06ss's Avatar
csc06ss
That's what I'm talkin about! The other subjections are good also, but if you drill and pin the cap and bars, they'll never move.
Scott
Old Apr 8, 2011 | 05:51 AM
brettnbama's Avatar
brettnbama
Man, I am probably jinxing myself, but I never had this happen. I did check the torque on the risers every so often though. You can't just tourque them down and assume they are good though, you got to look at the gap between the riser and the riser gap to make sure it is uniform. I will say that getting them to the 16 or so lb ft was nerve racking, especially after all the stories I have heard on here about stripped risers.
