Roto plate install
Old Apr 9, 2011 | 06:58 AM
Redder's Avatar
Redder
Default Roto plate install
Hi
for those with the roto plate ( not jr) how did you do the wiring? Where did you splice into for the power? Did you gointo the wiring harness under seat? Which wires?(color) I have a 09 xbones.
Thanks for help
Old Apr 9, 2011 | 07:50 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
I installed a different plate mount but used the blue wire off the rear wiring harness.
Drew
Old Apr 9, 2011 | 02:55 PM
Sgt Sportster's Avatar
Sgt Sportster
Should be the same, its the blue wire on my '10 Xbones
Old Apr 9, 2011 | 05:11 PM
Redder's Avatar
Redder
Ok thanks. I cant wait to install it! Darn slow fed ex!
Old Apr 11, 2011 | 01:54 PM
Sgt Sportster
Just looking at the schematic, if it has a brake light on it as well. The brake is Red/Yellow and Running light is the Blue. So if it has license plate illumination light it can run to the blue wire as well. Might need a load equalizer, if your turn signals start acting funny then you need one.
Old Apr 11, 2011 | 02:48 PM
brettnbama's Avatar
brettnbama
shouldn't need an equalizer for just a tail/running light. Especially if you are still running the stock tail light. IIRC you only need the equalizer for turn signals
Just Enough
Jul 14, 2015 07:37 PM
digitalhippie
Apr 24, 2012 09:14 AM
bmcgc
Dec 19, 2010 09:04 AM
Trip_D2
May 21, 2010 11:51 AM
albanynyharleyrider
Feb 12, 2008 12:38 PM
