How to wire side mount plate with panacea?
Old Feb 11, 2008 | 06:45 PM
albanynyharleyrider's Avatar
albanynyharleyrider
Default How to wire side mount plate with panacea?
Installed the panacea smoked tailight, brake, and directional unit from Kury. It came with an optional pigtail connector with run wire, ground and brake. Can I install a side mount license plate holder that has a run and ground wire for the led lights to illuminate the license plate only, using that pigtail adaptor connected into the panacea? Hope this makes sense...
Old Feb 12, 2008 | 07:28 AM
albanynyharleyrider
Default RE: How to wire side mount plate with panacea?
Anyone installed the laydown panacea multi-function taillight 4833 anda side mount plate with leds to illuminate the plate? If so, how did you wire it? Did you utilize the pigtail connector that came with the panacea kit to power a separate license plate light?
Old Feb 12, 2008 | 12:34 PM
pwer pla's Avatar
pwer pla
Don't have an answer for you but I have talked with kury's tech support a couple times in the last week getting all the parts needed to do some mods. They are very helpful give them a call I'm sure they will have the answer for you.
Old Feb 12, 2008 | 12:38 PM
albanynyharleyrider
Just tried calling and the phone rang and rang and rang.I have 715.247.2983 for the install number. I'll try again.
jd8181
Feb 21, 2012 03:47 PM
raysoftail
Nov 20, 2011 04:27 PM
hellfrozeover
Jul 25, 2011 04:18 PM
06chrisFTW
Jan 7, 2008 10:23 PM
flynavy
Oct 16, 2007 03:30 AM
