Need help : Cluth dont work.
Old Apr 9, 2011 | 01:39 PM
patharley's Avatar
patharley
Default Need help : Cluth dont work.
Cluth dont work.
I just finalised the installation of a wide swingarm. I reinstall primary chain with the cluth assembly, put back the oil and do a clutch ajustment like the clymer manual said.. but the clutch dont work. If I remove the derby cover, I can see the cluth push rod move when I touch the handle. I cant answer the problems.... Do I need more oil or something else ?
1995 flstc
Old Apr 9, 2011 | 05:01 PM
Other Sheep's Avatar
Other Sheep
What makes you think it's not working? Will it not roll with it in gear? That's normal for a harley. Or have you started it, put it in gear and get no movement from the bike?
Old Apr 9, 2011 | 08:01 PM
patharley's Avatar
patharley
When I hit the first gear with the cluth lever on, the wheel spin.
Old Apr 10, 2011 | 12:23 AM
Other Sheep
Is it off the ground when the wheel spins? Or is it burning rubber on the pavement?
Old Apr 10, 2011 | 06:05 AM
patharley's Avatar
patharley
off the ground, on a motorcycle jack.
Old Apr 10, 2011 | 12:37 PM
Other Sheep
Put it on the ground and try it. There will always be some friction even with the lever pulled in.
shyy
Oct 24, 2017 02:14 PM
bluethunder1949
Sep 6, 2008 03:49 PM
JosephGarcia
Nov 4, 2007 08:50 PM
**Blaze**
Apr 14, 2007 09:09 AM
rgm
Apr 12, 2007 08:57 PM
