Question on Signals not Flashing
Old Apr 13, 2011 | 09:14 AM
2006FLST's Avatar
2006FLST
Default Question on Signals not Flashing
Okay not getting any responses in the electrical forum so I will try here. I pulled the front signals on my 97 softail and plan to run bullet lights on the rear. I normally never run signals so this is a step up. On my previous 06 heritage I ran rear only for a while but the rear alone worked fine. On this bike pulling the front causes the rear to just stay on and not flash. Is there something I need to bypass?
Old Apr 13, 2011 | 05:39 PM
handyhoward's Avatar
handyhoward
Probably haven't received any answers because this is hard to understand... that said... I am guessing that your 97 has front and rear signals of some sort now and you are pulling them off and want to run with just the new bullet signals on the rear. Correct? If the rears are staying on and not signaling, you cut the turn signal relay out of the system... my guess is that the current flowed from the hot to the turn signal relay to the front turn signals to the rear turn signals. Just start tracing wires...
Old Apr 13, 2011 | 05:49 PM
Tom84FXST's Avatar
Tom84FXST
Check the resistance of the signals you removed, and replace them with a resistor of the same ohms...the bike thinks the bulbs are burnt out.
Old Apr 13, 2011 | 08:11 PM
2006FLST's Avatar
2006FLST
Thanks guys this helps. I will start checking wires.
JONESER900RR
Oct 23, 2017 09:59 AM
Napoli
Feb 27, 2012 06:56 AM
highwaythunder
Oct 2, 2011 07:09 PM
youngrider
Jul 27, 2010 03:57 PM
anubisss
Jun 16, 2008 02:31 PM
