tail light issue
Old Oct 21, 2006 | 03:02 AM
Wampuscat's Avatar
Wampuscat
Default tail light issue
Its rained alot here in Texas lately and I saw some condensation in the tail light lens. I took it off and dried it out,but when i tried to remove the buld it broke. The repair manual gives a Harley part number. But, I really dont want to drive 25 miles to buy theirs if one can be purchased at an auto parts store locally. I tried an 1157 , a GE P21, and a Sylvania 2357. None of these lock into place like the bulb that was in the light.
Anyone know of a bulb number that will match? Its for a "94 FLSTC Heritage Softail.
Old Oct 21, 2006 | 05:05 AM
PhantomMaxx's Avatar
PhantomMaxx
Default RE: tail light issue
For a 2006 FB it's 1157. The 1157 should have two conducter leads on the bottom and two post on the shaft at different heights on the shaft. Simular to below.
Old Oct 21, 2006 | 05:15 AM
millzog's Avatar
millzog
Big Kahuna HDF Member
Put some electrical grease on plug end so the next time you need to replace it , it will come out easier . 1157 should work , I have an auto bulb in mine for 5yrs so far.
Old Oct 21, 2006 | 05:26 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
ORIGINAL: millzog
Its called dielectric grease and you want to put some in because its completely water proof. So even if you filled the light up with water it will still work properly. It will also prevent any corrosion to the bulb contacts and the sockets connections.
bigpappa160
Electrical/Lighting/Alarm
May 3, 2018 11:39 AM
hamdizle
Jun 27, 2013 10:44 AM
Gregte
Sep 2, 2009 02:45 PM
jankowb
Aug 31, 2008 09:34 AM
stevieg
Jan 2, 2008 01:32 PM
