fatboy rear tail light
Old Jun 24, 2013 | 12:08 PM
hamdizle's Avatar
hamdizle
Default fatboy rear tail light
My fatboy's rear tail light turns it self off when I'm riding....at night when the bike is cold the tail light works just fine but after riding for a bit the tail light turns off....the blinkers and brake lights work just fine...no tail light at night is bad....any thoughts?
Old Jun 24, 2013 | 12:18 PM
dub976's Avatar
dub976
Does it have a turn/brake signal converter? I had the same kind of issues but would also loose my headlamp. It ended up being the hd controller
Old Jun 24, 2013 | 12:32 PM
_Gir_'s Avatar
_Gir_
My guess is chase the positive wire for the run light. Also, it could be the bulb.
Old Jun 24, 2013 | 12:50 PM
Skeezmachine's Avatar
Skeezmachine
Start simple. Remove the tail light and check the socket. I've never heard of a bulb that only works some of the time but stranger things have happened. As for the socket, it may be a little warped. Maybe it got hot and some point? If it's like all the others I've seen then it's made of a gray, hard rubber material that is susceptible to warping under heat such as from a bad bulb. It's possible that when the bulb warms the socket up it causes it to warp/expand a bit and the contacts no longer line up with those of the bulb. Then once the socket cools down the problem goes away.
I had something similar to this except that in my case, the socket first got melted and warped when I had a stop light that was always on. One I fixed the brake so the bulb worked as it should, the partly melted socket's performance was spotty. I was able to remedy the problem by bending the connectors inside the socket out a bit to ensure they were making contact with the bulb. This completely fixed the problem. If you try that, make sure you unplug the socket from the bike. Sticking a sharp metal object like an electrical pick in there and touching two different connectors will result in some slight fireworks!
Old Jun 26, 2013 | 10:24 PM
hamdizle's Avatar
hamdizle
now the tail light doesn't work at all..tomorrow ill start checking the wires for power in the tail light. mabey the wire broke or something....
Old Jun 27, 2013 | 06:47 AM
srt8's Avatar
srt8
my 2cents.... check the bulb first, then check for power at the socket and work your way back to the controller
Old Jun 27, 2013 | 10:44 AM
knightenforcer's Avatar
knightenforcer
Check the fuse. Mine looked good on the outside, then I started pulling em out and found some have the contacts dirty and corroded. Worked better after cleaning and installing new ones. Just my 02 cents.
IBADB
Aug 16, 2012 01:14 PM
Timmy B
Aug 4, 2012 02:40 AM
lance romance
Aug 30, 2010 08:17 AM
klf33
Jun 23, 2009 10:39 AM
jankowb
Aug 31, 2008 09:34 AM
