bolt -in cams
Old Apr 25, 2011 | 07:30 PM
davidrock59@yahoo.com's Avatar
Stage II
Default bolt -in cams
lookin at installing a andrewsTW26A cam in my 2002 fatboy what are the disadvantages and other issues that i may come across with this installation it is carb model appreciate any input
Old Apr 25, 2011 | 07:38 PM
tlb's Avatar
tlb
You are going to have to decide if you want to replace your stock tensioners, or go with the upgrade.
Old Apr 25, 2011 | 08:32 PM
poppavein's Avatar
poppavein
I'm happy with the TW26G cams in my 2002 Road King. I went with the gear cams (and peace of mind.)
Old Apr 25, 2011 | 09:15 PM
Bluehighways's Avatar
Bluehighways
I have 26H's in my 2010 103" in an otherwise Stage 1 engine. Very nice power band, nice lope at idle (850 RPM), noticeably louder than the stock cams, no lag at low RPM's and still pulls strong long after I get nervous about the high RPM's and shift into the next gear.
Old Apr 26, 2011 | 03:42 AM
oct1949's Avatar
oct1949
I am happy with ours..
great for 2 up putting around and still hangs in when I wind her out.
Plus's are,, lot better ride-ability, better fuel mileage, and cooled her oil temp about 15* and easy on valve train.
No minus's as far as I am concerned.
Old Apr 26, 2011 | 05:17 AM
roadkingharry's Avatar
roadkingharry
I have the 26A, nice cam. Replace your inner cam bearings while you're in there with Torrington B148's. If you really want a nice bump, go to 95" and have your heads worked over. Depends on your budget.
Old Apr 26, 2011 | 12:41 PM
klf33's Avatar
klf33
Have you considered upgraded your tensioners to Hydraulic style while you are at it ? and go with an 'N' cam from Andrews ?
The 26 will probably roughen your Idle, my 37 made my idle tricky a bit when the bike is cold.
I would highly recommend the upgrade, my cam tensioners were not only shot at 37K miles, but the cam bearings were a disaster waiting to happen
apetterez
Mar 15, 2017 03:23 PM
gi_king_ken
May 19, 2013 02:03 PM
Tex Bill CC
Aug 5, 2010 01:30 AM
GlennsGlide
Oct 20, 2007 02:28 PM
raym
Exhaust System Topics
25
Jul 20, 2006 11:02 PM
