Help adjusting shocks preload
Old Apr 26, 2011 | 09:51 PM
fastdeuce's Avatar
fastdeuce
Default Help adjusting shocks preload
Adding some preload to the rear on my 01 Deuce. I have the factory shop manual and the special tool. I did what the book said, loosened the nut and turned the special tool about 2 holes and tightened the nuts. When I look at it, it seems like the canister should be held still while the special tool backs out the end a couple holes! I can't tell any diference in the ride so I didn't go enough or must hold the cannister while adjusting. Thanks for the comming advice. Rick
Old Apr 26, 2011 | 09:58 PM
MCSarge's Avatar
MCSarge
I thought so too about the canister. You loosen the lock nut and turn the whole thing. If you look at the back end of the shock opposite the lock nut you can see how far it is moving. I have the lowered shocks on my bike and it is easier for me to see how far the shock has moved by looking there. Just make sure that they are both adjusted the same distance.
Old Apr 26, 2011 | 10:10 PM
Misbehaven's Avatar
Misbehaven
If you only turned it two holes you won't notice much of a change. Look in your book and adjust to the your weight. Mark the shock with a piece of tape or marker and where the manual says to turn the shock they mean 1 full turn not just a hole or two. Hope this helps.
Old Apr 29, 2011 | 11:01 AM
fastdeuce's Avatar
fastdeuce
Thanks for the help. I adjusted up to 360 degrees of rotation. The shinny strip on the rear wheel end looks to be the same on both shocks. Should get a few nice days again next week so I get to try it out. I've gained about 20 pounds since 2001. I don't want to spend $ for new ones until these are shot. Thanks Rick
Old Apr 29, 2011 | 12:36 PM
JakesDad1's Avatar
JakesDad1
You should be all set. I think it was 2 full rotations to full hard.
dontdropit
Milwaukee Eight (M8)
19
Feb 28, 2019 08:23 PM
magnum629c
Jul 14, 2015 12:55 PM
sroc3
Apr 13, 2015 10:39 PM
prstaples1911
Apr 13, 2013 10:38 PM
Mrkicks
Oct 20, 2005 10:23 PM
