Wrench it myself? **Update**
Good point about torque wrenches. If it is a non-critical install just use (hopefully) your experience to tighten the fasteners. If there is a gasket involved, other than the oil filter, get out the torque wrench.
I have also run in to the rediculously tight fasteners-and the oil filter! Got to think they over-tightened it just because they knew I would be doing my own oil changes after the 1K. Just compress that gasket a little over hand tight.
I use two (ex)cat litter boxes to do an oil change (one under the filter and one under the drain plug). They are low enough to fit under the frame and big enough to be able to place them under the bike so I can stradddle it while the oil is draining and lean it to both sides to get as much as possible out without getting the oil all over the floor.
Doing your own wrenching is extremely satisfying!!
Excellent idea about the litterboxes. I just need to get me a cat so that I can use him to wipe up any leftover oil that spills on the floor.
You know I didn't even think about the issue of where the oil filter was until you all mentioned it. I have to imagine that it along with the crankcase are still completely full even after draining the oil tank since they are both lower. Another victory on the war of engineering vs serviceability.
I was also considering doing the modification to the automatic primary chain tensioner. Any difficulty with this? Do you have to remove the outer primary cover, or can you do it through the inspection/derby cover?
For the oil filter, just cut a plastic jug or use a piece of tin or even put some alum foil under the filter and make the oil funnel off the front side of the motor.
After doing the 10K service this weekend myself, I have to say that Harley's are pretty damn easy and fun to wrench on.
For the $560 the dealer wanted to do the 10K service, I was able to buy all the parts and 6 qts of oil for the engine-tranny-gearbox (Mobil1 V-Twin formula - Thanks Babs)âŚ
âŚas well as getting a cool new HD derby cover, a new Craftsman professional aluminum motorcycle lift (yeah, itâs the yellow one), two Craftsman torque wrenches, a set of Craftsman standard/metric allen bits, a 12 pack of Bud Select, and still had $70 bucks left over. YEAH BABY!
I couldnât believe how easy it was to adjust the clutch and throttle cables (I have a carb). I can pull the clutch with one finger now and the throttle is so smooth. The aluminum foil trick under the oil filter worked like a champ! (Thanks fxstcguy98)
The thing that I think made the most difference was the plugs. Neither I, nor my dealer had ever changed the plugs since I bought the bike. The plug ends looked like something that you would find at the bottom of your barbeque grill.[:'(] I figured that it was due to a rich air/fuel mixture.
The carbon had built up so much that there was no gap between the electrodes. I canât believe that it was still running. Come to find out, the wife uses the chokeâŚ.eh-em, enrichner circuit every time she starts it, and sometimes forgets to close it back up.[:@]
This bad boy screams now. It pulls hard all the way through 5th gear.
Thanks again you guys for all your help.[sm=smiley20.gif]
P.S. â For those of you with lowered bikes, you have got to get the Craftsman Professional jack. I was using the $50 Big Red jack before, but the Craftsman goes way lower. I didnât have to ride the bike up any 2X4âs or ramps just to get the jack under. And it is 100% sturdier and a hell of a lot lighter.
That fix my hog video is great! worth the money.
Aluminum foil under the filter... hey hey I learned something today too.. good trick!
Did you find anything in the 10k that was extremely difficult or tricky or odd?
Howbout the forks.. brake fluid, etc.. fallaway check, etc?
I haven't looked at the 10k in a while myself to see.
I need to get a grease gun I suppose for the neck bearing.
Well.. Off to Disneyland with the family tomorrow for turkeyday.
Have a great Thanksgiving!
God bless our folks over seas getting the job done for us that can't be home for Thanksgiving this year.
Scott
Yeah you should notice with the M1 in the engine running a bit cooler.
Scott
Have a great time with Mickey and the gang!
