Problem starting Heritage
Old May 5, 2011 | 06:19 PM
Slatts's Avatar
Slatts
Stage IV
Unhappy Problem starting Heritage
Not sure if this is the correct place to post, so please redirect me if it is not.
I currently have an 08 Heritage with dealer installed security.
She is not turning over. Feels like it is electrical but not sure how to diagnose it.
Battery is good (new), lights works, security lights trigger turn signals correctly, headlight on, fuel injection sounds like in fires, but when i hit the start button, i get nothing. No cranking, no nothing.
Any ideas before it goes to a dealer to be worked on?
Thanks,
Old May 5, 2011 | 06:26 PM
doghair's Avatar
doghair
Check the fuses?
Old May 5, 2011 | 06:29 PM
jlasoftail's Avatar
jlasoftail
Use the search option and you might find something to help. I'm sure I read something similar before, but I can't remember. Seems to me there is a wire that has a habit of breaking off. I hope someone with more info for you can chime in here. I'd start my search at the starter though if it was me. Have you checked your fuses?
Sorry I'm not much help...
Old May 5, 2011 | 06:32 PM
Slatts's Avatar
Slatts
Stage IV
Fuses all look good, but I did not test them for a cracked one.
Old May 5, 2011 | 06:33 PM
jeffreydsilver's Avatar
jeffreydsilver
Default Neutral Safety?
Try shifting into neutral before pushing starter button? Not sure if you have a neutral safety switch on your bike!
Old May 5, 2011 | 06:47 PM
Slatts's Avatar
Slatts
Stage IV
Yep it is definately in neutral. It has a neutral light that is lit. I did manage to start it one time last year when it was in gear, having the clutch pulled back. Letting it out lit my eyes up - that's for sure. One lesson I learned.
Old May 5, 2011 | 07:14 PM
fcsallan's Avatar
fcsallan
Without crank it has to be somewhere between the stop/run switch and the start button and the starter. I would think it is a relay that you trigger when you push the start button which actually triggers the starter. I would pull and reseat all of the relays under your seat and possibly swap around the similar ones to test them. I suspect either a bad relay or a dirty one.
stevevfd's Avatar
stevevfd
I had that happen to me and it turned out to be one of the grounding screws under the seat, just in front of the battery, had loosened up. I tightened it up and I was good to go. Start with the easy stuff and make sure your battery connections are all tight.
Old May 5, 2011 | 07:51 PM
mike 09's Avatar
mike 09
I dont know about the security system you have but if you have a key fob I would replace the battery. I understand this happens often. Good luck, Mike
Old May 9, 2011 | 10:51 AM
Slatts's Avatar
Slatts
Stage IV
Default Problem Solved
Thanks guys for all the helpful input.
Here's what I learned... The security system kills the start function and requires the fob to be active. I changed out the watch battery in the fob and it started perfectly. Only cost me $1.99 for the watch battery, and a week of frustration.
I appreciate everyone's help.
