Rocker C - Completed Conversion
Old May 15, 2011 | 11:12 AM
jaysonL's Avatar
jaysonL
Man I love the Rocker + Heartland conversion ! Absolutely sick !
Old May 15, 2011 | 12:47 PM
Eastcoastmax's Avatar
Eastcoastmax
Originally Posted by DavTN
Looks damn good. I pick mine up soon and plan on doing something similar with the tail light. Did you fab the LED channel? Any pics and details of the process would be appreciated.
Hi guys
Thanks for all the positive comments.
For the channel, it was fabricated by someone associated with my local dealer, but basically it was an L-shape peice notched into the bottom lip and closed off at either end. It also has a hole in one side where the wires feed through. I've attached another closer view photo which hopefully helps, if not I will try and get some different ones.
The LED strip was a total of 11" long, including 1" either end for the turn signals, leaving 9" for the brake/run light.
Old May 15, 2011 | 06:51 PM
tc1816's Avatar
tc1816
Nice work, i really like the LED strip.
Old May 15, 2011 | 09:25 PM
Tom84FXST's Avatar
Tom84FXST
Looks Good....good luck with the Radiantz LED...I used them and it started burning out in 6 months...they wanted me to send it back, so they could see if it got wet????WTF...I finally said screw it and got Custom Dynamics ...it was brighter from the get-go and is holding up well.
Old May 15, 2011 | 09:46 PM
Hawaii-Five-Jo's Avatar
Hawaii-Five-Jo
Look sick! luv that LED strip
Old May 16, 2011 | 10:54 AM
DavTN's Avatar
DavTN
Originally Posted by Eastcoastmax
Hi guys
Thanks for the details and the close-up pic!
Old May 16, 2011 | 11:00 AM
TIPN8R's Avatar
TIPN8R
Hi guys
Sort of the same thing I did. I slotted the fender near the edge, then welded in a piece of sliced SS tubing for a channel. Then drilled out one end for wires and epoxied it in place.
Here's an old picture:
Your ride came out sweet!
Old May 16, 2011 | 11:11 AM
Kowan's Avatar
Kowan
Nice clean job on the channel and blending it in TIPN8R.
Old May 16, 2011 | 11:23 AM
felixsum's Avatar
felixsum
Love the led
Old May 16, 2011 | 07:13 PM
j33ptj's Avatar
j33ptj
Here is my LED, on the shorter fender version (see sig picture)
It takes a little more work as the strip has to be cut to allow it to bend "vertically"...
Robert
