Internal Brake Line in Forks
Old May 16, 2011 | 05:08 PM
The Count's Avatar
The Count
Default Internal Brake Line in Forks
After 3.5 months I finally got my forks in! They have an internal brake line that comes out the top of the fork but I ran into a issue... I have a set of apes with black magnum cables but the cable out of the fork is steel/grey colored. Anyone know of a connector I can use to connect the two so I can rock 3 black cables instead of 2 black and 1 steel/grey?? Magnum has a "rear brake tee" that looks like it might serve the purpose but I'm not sure. Anyone ran into an issue like this before?
Old May 16, 2011 | 05:19 PM
RICHIEMACK's Avatar
RICHIEMACK
I think if you can do it,it would look worse than the off color,since it already apart why don;t you just put a black cable sleeve on all of them
Old May 16, 2011 | 06:30 PM
The Count's Avatar
The Count
Only options are to leave it as is, try to find some sort of sleeve to match my black cables or cut the 2 and try to make them 1. I have the black pearl magnum cables and I'd like to keep them all looking the same. I'm waiting for the spike caps that go ontop of the forks to be shipped.Theres a hole in the back of the spike where the brake line comes out and goes up to my handle bars. I'm hoping to connect the two and hide the evidence in the spike cap. Not too sure how big the caps are but thats best case scenario.
Old May 17, 2011 | 10:49 AM
The Count's Avatar
The Count
Bump... anyone know if this part will work if I cut the two cables and use this to connect them?
bellgnte
Oct 19, 2012 07:46 PM
olgreydog7
Apr 15, 2008 12:20 PM
HaggisMan14
Feb 5, 2008 08:31 AM
reded
Jan 23, 2008 08:58 PM
KY23
Sep 21, 2006 12:31 PM
