question about air filter on rocker, need advice
Old May 17, 2011 | 02:52 PM
RockerFF's Avatar
RockerFF
6th Gear
Default question about air filter on rocker, need advice
Got my new 2010 rocker, love it so far. Of course i want to start tinkering with it. For my first mod I though about changing over the intake to a K&N or something like that. I like the exposed look of having the intake showing. My question is, will I be required to do any re-jetting or anything? Can I just order the intake and slap it on and be good to go?? help is appreciated!!!
Old May 17, 2011 | 02:55 PM
HDCrossbones09's Avatar
HDCrossbones09
If you have the stock pipes with baffles installed you should be okay. If you have some better flowing exhaust it will run too lean and you will need a tuner.
Old May 17, 2011 | 02:58 PM
RockerFF's Avatar
RockerFF
6th Gear
I have the stock exhaust on now, not planning on changing anytime soon. Has anyone had any experience with just changing the intake? Thanks for the quick reply crossbones!
Old May 17, 2011 | 03:36 PM
chuckdizzle's Avatar
chuckdizzle
You should have no issues with the fuel from just changing the intake, check the plugs and see how they are burning after you get a ride under your belt.
Old May 18, 2011 | 11:04 AM
lazyboy09's Avatar
lazyboy09
Just changing either the air cleaner or exhaust should not be an issue. If both are changed you will most likely have a lean running condition, which will require a tuner. Believe me, once you make that first mod it'll never stop.
LOL!
Old May 18, 2011 | 11:19 AM
Maclugie's Avatar
Maclugie
lazyboy09 that is the best looking Rocker I have ever seen. The license plate is unreal! Very Nice!
Donttreadonme21
Exhaust System Topics
Feb 17, 2013 03:38 PM
SteveHarley14
Jul 13, 2009 11:48 PM
Ow R Ya
Jun 15, 2009 06:52 AM
calib9
May 10, 2008 01:00 PM
drkenigma1
May 5, 2008 09:44 PM
