Progressive Drop In?
Old Jun 27, 2011 | 09:30 PM
ghostrider69's Avatar
ghostrider69
Default Progressive Drop In?
A buddy of mine pulled the Progressive drop in kit out of his 2008 Softail before he traded it in on a Street Glide. He gave me the kit but he threw away the PVC spacers. Just curious if anyone knows what size PVC pipe I need too make the spacers with. I think they should be 3/4" but I am not positive. I would like too start off lowering it 1 3/4". I just need too know the size and length of the PVC.
Old Jun 27, 2011 | 10:12 PM
Misbehaven's Avatar
Misbehaven
This link may help ya.
https://www.hdforums.com/forum/softa...p-by-step.html
Old Jun 27, 2011 | 10:36 PM
ghostrider69
Thanks for the link.
Old Jun 29, 2011 | 05:52 PM
POPASICKBOY1's Avatar
POPASICKBOY1
C
The spacer is slightly smaller than the washers and springs and if you have a 09 or newer you can't use them
Old Jun 29, 2011 | 06:02 PM
ghostrider69
Originally Posted by POPASICKBOY1
C
The spacer is slightly smaller than the washers and springs and you want a 1 inch length
Are you saying I need the spacer to be 1" long? I have recently read everywhere that for a 2" drop the spacers need to be 3" long so if I need a 1 3/4" drop then I figured the spacers need to be 3 1/4" long.
Old Jun 29, 2011 | 06:10 PM
POPASICKBOY1
What year and model do you have? And the longer the spacer the higher it will sit, the more you cut it the lower. I just got mine today
Old Jun 29, 2011 | 06:19 PM
ghostrider69
2011 Deluxe
Old Jun 29, 2011 | 07:39 PM
POPASICKBOY1
2011 Deluxe
Kit will not work on a 2011 only up to 2008
Old Jun 29, 2011 | 07:56 PM
ghostrider69
What????? Please see the link below. It shows kit #10-2003 is to be used on most all 1984 up Softails and 1984 up to 2011 FLST.
Here is the link for a 2011 FLST
http://www.progressivesuspension.com...37&modelID=665
Here is the link for a 1984 FLST
http://www.progressivesuspension.com...37&modelID=664
Here is the link for a 2008 FXST. Which is what my buddy pulled the kit out of.
http://www.progressivesuspension.com...7&modelID=1223
Do you notice that they all call for the same Drop-In kit?
Old Jun 29, 2011 | 08:55 PM
Roberto o8 Deluxe's Avatar
Roberto o8 Deluxe
That is the right part # just did mine, cut the pvc spacer to 3.25" gave me about 1 3/4" drop. Rides great with stock oil and no ricors. Just for fun i may install ricors and change oil to see if rides better
