Best cams for 95" SE engine?
Old Jun 30, 2011 | 09:56 AM
Sgt_Jim's Avatar
Sgt_Jim
ok, hijacking briefly.. This comes back to a few weeks ago when I was asking a bunch of questions about different cams and the Woods 555's or something.. I was talking to my neighbor about it (a machinist) and he was preaching "You won't see the same results unless you get your heads done too".. and although I know how an engine function, I don't know anything about the details..like I didn't know what cams were until i started asking questions.. so my next question..when people say "get your heads done" or "get head work done".. what are they referring to? Like what does it mean? ..also going to google now i guess to study
..to answer my own question, i guess it's to increase the quality and quantity of intake and exhaust.. but like.. what actually goes into doing it?
Old Jun 30, 2011 | 10:03 AM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
I'm thinking of having my heads done by Branch. Already have SE 95" kit and Andrews 26g. Wonder if the work will be worthwhile.
Old Jun 30, 2011 | 10:06 AM
Fireman1501's Avatar
Fireman1501
The heads from the factory have casting marks in the runners.. A port and polish will smooth out the runners to get the extra power. The casting marks make the air and exhaust tumble in the ports. Which cause friction. By smoothing out the ports your air and exhaust flow smoother without all the friction. Which will increase the amount of air that can flow.
Old Jun 30, 2011 | 10:55 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Originally Posted by KumaRide
37's move tq to the right. 21's to the left, 26's to the left of 37's. Headwork, increasing compression, can increase tq. But, too much compression and it will ping. Especially at lower rpm's, to the left. I'd look into 204's, possibly with a 4 degree advance key. Getting 105 tq in a 95" is setting high expectation without spending lots of $$$. Your 95 tq with stock cams and 95" kit is very good. That is close to what cammed bikes with 95" kits get. So, maybe with your dyno guy it is possible. In other words, not all dyno numbers are created equal.
The cams are 203's.
Old Jun 30, 2011 | 01:01 PM
hspring03's Avatar
hspring03
I have a whole SE build.
I know if I went aftermarket I would have got better numbers, but i very satisfied
SE performance heads w/comp releases
SE high Comp Pistons
SE 257 cam
Bassani 2in1
Power commander tuned by Cycle Performance
100hp/100tq
Old Jun 30, 2011 | 02:42 PM
fat15th's Avatar
fat15th
here is my 95ci dyno before and after head work from hillside with fatcat,pcIII,bored throttle body,andrews 37,zippers high flow ac
Old Jun 30, 2011 | 03:07 PM
mike06train's Avatar
mike06train
[quote=DR. V-TWIN;8515139]I'd think you would gain about 10 hp and tq with heads or headwork and the 37. There is a great site with tons of dyno sheets for varying builds but i can't remember what it is right now.
Drew[/quote
Are you talking about www.nightrider.com ? They have alot of good info on different builds.
DEDO1369
Engine Mechanical Topics
29
Aug 3, 2014 09:40 AM
Duc
Jul 29, 2014 03:00 PM
W0ace
Feb 27, 2011 11:36 AM
hougz79
Sep 6, 2010 10:20 PM
masterblaster
Mar 28, 2010 08:41 PM
