Need help finding rubber holder grommit thingy
Old Mar 15, 2012 | 08:32 AM
  #41
hspring03's Avatar
hspring03
So you need a wider spool...
Does the backrest "lock" into this spool, or just rest on it and lock further back?
Old Mar 15, 2012 | 09:18 AM
  #42
rsarno's Avatar
rsarno
It is a different backrest, but same mounting as this:
Old Mar 15, 2012 | 09:22 AM
  #43
hspring03's Avatar
hspring03
Pay no attention to the "dyna" title....
Page 2 diagram....
You need number 3(spool) and the number 2 bolt but probably longer. You can get the bolt at any hardware store...
http://www.harley-davidson.com/en_US...ts/-J03709.pdf
Old Mar 15, 2012 | 09:28 AM
  #44
rsarno's Avatar
rsarno
I wish this forum had a "Thanks" button on posts
Just to be clear, the same spool will be on all 4 points, and ill get 4 long bolts, and a washers (id like to add the washers).
I wanted to clarify, is this method intended on changing out just the one post with the broken pin, or all 4?
either is fine, id prefer a complete conversion so its all consistent
Old Mar 15, 2012 | 09:36 AM
  #45
hspring03's Avatar
hspring03
I would only change out the one....
If you keep an allen in your bag, you can use the push pins to keep it detachable and spin the one allen head off quicker.
By changing out all the bolts it's really no longer detachable..
If you want to change all four.. you will need 2- number 1 spools and 2 number 3 spools.
This is just a simple solution to get you through the issue your having.
if you want a "permanent" fix and want to stay detachable, I would look into the barebacks detachable system, but it will be a little more that a $7 spool and a $3 bolt.
Old Mar 15, 2012 | 09:41 AM
  #46
rsarno's Avatar
rsarno
Understood. Its actually a solution i wouldn't mind doing for all 4. I only pull bags when im cleaning, and spinning 4 bolts is no biggie ... in exchange for piece of mind every time i snag a nasty bump
Really appreciate your help here!!
Old Mar 15, 2012 | 10:13 AM
  #47
hspring03's Avatar
hspring03
One more piece to add here...
If you don't care about the detachable bag aspect, one way is to go back to the HD hardware kit. It comes with all the spools and bolts you need for your bags.
Here is the spec sheet from HD.
http://www.harley-davidson.com/en_US...re_227-229.pdf
According to that, for your bike you need this kit
53931-03A
http://www.latus-harley-davidson.com...geshoppingfeed
Old Mar 15, 2012 | 11:00 AM
  #48
rsarno's Avatar
rsarno
Im seeing a stud on another diagram, PN 90387-03
does the kit you linked above use this same sort of stud and just doesnt come with it?
or is it a different mechanism altogether?
thanks
Old Mar 15, 2012 | 11:06 AM
  #49
hspring03's Avatar
hspring03
I don't think the picture associated with the link is actual..They seem to use the same picture for every kit number. I'm betting it contains the studs you found a part number for. The picture in the link would be for a softail standard or other "non" bagged softail.
Old Mar 16, 2012 | 11:46 AM
  #50
rsarno's Avatar
rsarno
FYI i did order the kit! Found it for $33 on surdyke
Thanks so much for your help, this would have plagued me for months until i eventually drop a bag and it costs me $600 + a new mount kit hehe
extremeshot
Jul 21, 2014 03:32 PM
airforceacop
May 10, 2012 10:59 PM
studiopeg
Feb 19, 2012 07:19 AM
Big Jake
Jan 24, 2011 08:29 PM
straitshot151
Jan 20, 2006 11:44 PM
