Bike is having issues
Old Jul 17, 2011 | 04:29 AM
tatfanatic69's Avatar
tatfanatic69
Stage I
Default Bike is having issues
I have a 2000 soft tail night train when i am riding the bike for about 20 to 30 mins on the highway when its real hot out the electrical starts to cut out which then makes the motor start cutting out I took it to harle they could figure out what was wrong but at night when it cools down a bit no issues anyione have any ideas please
Old Jul 17, 2011 | 05:12 AM
TalonIILM's Avatar
TalonIILM
Lightbulb Train Stoppa Rollin...
Sounds like the coil is breaking down once it gets hot... Try swapping out coils, they gotta get good and hot for a failure to show up when coils start to die. Had em drive me crazy more than once.
TIILM
Old Jul 17, 2011 | 08:00 AM
roadkingharry's Avatar
roadkingharry
What TalonIILM said. If you have a meter, you can check the coil before you go out and buy a new one, but you have to check it after the bike cuts out on you. Go here to read an explanation of the process but double-check it in your service manual.
Old Jul 17, 2011 | 08:09 AM
mike06train's Avatar
mike06train
+1 on the coil.
Old Jul 17, 2011 | 08:27 AM
tmitchellof PG's Avatar
tmitchellof PG
+2 on the coil
Tom
Old Jul 17, 2011 | 09:14 AM
JohnnyC's Avatar
JohnnyC
A 12 year old bike could have any number of issues causing it to cut out after a 20 to 30 minute run.
Test the coil but also be concerned that the cam sensor and the ignition module typically only fault when heated. Using a heat gun you could expose the cam sensor (under the derby cover) and heat it to see if it faulters while the bike is idling. Same goes for the ignition module. Coils go bad but odds are better for it to be the module or sensor.
You could even have something as simple as a loose connection that is effected by the heat of the engine. Or simply a wire broken inside of the insulation that only stretches and breaks contact under the operational heat of the engine.
yorgle7
Aug 6, 2016 12:02 PM
michael 53
General Topics/Tech Tips
Jun 13, 2013 01:06 PM
bigred292
Sep 24, 2012 12:21 PM
bmyers2500
Oct 16, 2009 08:01 AM
byrdi
Oct 7, 2006 01:06 PM
