periodic starting problem
Old Jul 24, 2011 | 08:38 AM
Edywazoo's Avatar
Edywazoo
5th Gear
Smile periodic starting problem
Hello all.
Yesterday I had rode all morning without a hitch, got home and the bike sat for 5 hrs or so.
I wnt to go out again and it started for a split second and then shut down. After that I had no response, the moter turned and turned but nothing. I believe it to be no spark so I seached high and low for a bad ground wire some where but could come up with nothing.
I pushed it into the garage pissed off and just for the hell of it i tried to start it again................................Started right up!
Does anyone have any thoughts on this? the bike is a 96' FXSTS never had any problems ever with this bike and i have had it for 8 yrs and its always beed kept up proffesionally
Thank you
Old Jul 24, 2011 | 10:11 AM
Edywazoo's Avatar
Edywazoo
5th Gear
Still no ideas? anyone
Old Jul 24, 2011 | 01:01 PM
PeteRock's Avatar
PeteRock
Originally Posted by Edywazoo
Hello all.
Thank you
Knowing and believing are two different things. NEVER assume, always check so that you are not chasing ghost problems. However if no spark I would first look at switches (key and or handle bar) if problem happens again you can try and cycle the switches a few to many times.
Good luck intermitting problems can be VERY fustrating.
js.murphy@shaw.ca
Jun 24, 2016 03:53 PM
Scorpio49
21
Jan 1, 2014 12:00 PM
srgtstadanko
Exhaust System Topics
Nov 17, 2009 03:24 PM
El Cid '93
Sep 3, 2008 10:56 AM
zenwarrior
Jul 8, 2007 04:48 PM
