Windshield on a Deuce, worthy?
Old Nov 12, 2006 | 11:02 AM
AsahiToro's Avatar
AsahiToro
Default Windshield on a Deuce, worthy?
I'm considering a windshield for my 07 Deuce. I get a lot of wind, bugs, rocks, etc. at higher speed, hwy riding and I'm wondering if a windshield would alleviate some or all of this? Does it make the bike more unstable in the high wind? I not concerned with this on shorter, around town, through the country rides but like the idea of having a detachable option for longer hwy rides. How effective is the HD windshield? Is it easily detachable and is the hardware left over when the windshield is off concealed enough or an eye sore?
Thanks for any input.
Old Nov 12, 2006 | 11:17 AM
Deuce Bigelow's Avatar
Deuce Bigelow
Default RE: Windshield on a Deuce, worthy?
I was thinking about the same thing.
HD has a new quick release detachable windshield, it uses clamps and has no hardware that gets left on the bike.
it's VERY nice![8D]
Old Nov 12, 2006 | 11:29 AM
Alien Spyder's Avatar
Alien Spyder
I usually throw my deatchible windshield on when the fall temps start to drop below 60 degrees or if I'm going on a long highway ride.
I don't think it makes the bike unstable at all.
The new hardware Harley came out with is great!
Good luck!
AsahiToro's Avatar
AsahiToro
Thanks for the reply Uno Deuce,
Bitchin' Deuce you have there BTW. I like the flush gas cap mod you did (read about it over at VTF). If I was handy with a heat gun and not worried about screwing the whole thing up, I'd do the same.
That sounds good about the new windshield mounting. Now if I can just figure out if it will help much relative to cost and not blow the bike all over the place in high winds.
Thanks again.
Old Nov 12, 2006 | 11:30 AM
AsahiToro's Avatar
AsahiToro
Thanks Alien,
Does it help much with the wind, rocks, bugs, etc.?
Old Nov 12, 2006 | 12:46 PM
voodoo93's Avatar
voodoo93
I find that even the small (14") windscreen that I have on my bike makes a world of difference... does not cause issues with wind and definitely helps with road debris - at 80MPH you can ride instead of merely hold on. It is not a quick detach but does come off very easliy with no hardware left behind in the event you want to cruise without it - however it blends pretty nicely and IMHO does not detract from the bike even when it is left on.
Old Nov 12, 2006 | 12:57 PM
mimo's Avatar
mimo
I was just about to tell you to check out Vodoo's ride.
Yes the windshield makes a world of difference, check out the Harly new one (clamp attached).
Regards.
Old Nov 12, 2006 | 03:12 PM
pro1955's Avatar
pro1955
I run my detachable windshield on long road trips and cold weather, its the only way to go.
Old Nov 12, 2006 | 03:21 PM
rlj2's Avatar
rlj2
The windshield is great for highway, like voodoo says, your not holding on, just enough to take the main wind pressure off of you.
i bought one of the new windshields with clamps for my wifes sportster. Its great. Didnt know they started making this style
for the deuce. Mine is detachable, but leaves behind some hardware when off. Plus the clamps seem alot more secure.
Old Nov 12, 2006 | 03:44 PM
1deuce3's Avatar
1deuce3
voodoo, what make is your windshield, and how does it mount, and in how many points? On the risers?
