Deuce Wheel Axle Size?
Harley wheels of that generation will all take 3/4", 1" or 25mm bearings, which are all the same OD and the bearing kits (intended for installing in new custom wheels) come with all the necessary parts to convert. In the case of a softail wheel, like our Deuce rear, the hub may need to be machined, as I did.
I worked on the principle that I needed bearings and a spacer, so was prepared to buy factory first time. That way, if the bearings are a stock size and not a Harley special, I have in my hand the identity of any replacements I may need in future.
Hope that helps.
