dragging floor boards
Old Aug 14, 2011 | 09:33 PM
Quadancer's Avatar
Quadancer
Bullcrap. It's a great bike all except for the low profile. I put 5/8" PVC slugs over my springs, changed to thicker fork oil (which I may have not needed, but it keeps the head up in sweepers) and welded head bolts underneath the boards that hit just before the board will.
I would get slightly longer tubes and tins if I could afford it; 1" would be perfect.
Ride 'em like ya know how man.
Old Aug 14, 2011 | 09:34 PM
oct1949's Avatar
oct1949
Don't know if U bragging or bit(hing.....
Is Ur bike lowered, front and/or rear,, that might cause some of Ur problem.
Old Aug 14, 2011 | 09:57 PM
t stone's Avatar
t stone
Originally Posted by s.ga.rider
Is their anything you can do to a heritage to keep from dragging the floorboards? I have had the bike a week now and already have noticeable wear to both floorboards.
i can take a curve at a slow to moderate speed and it will drag every time.
my yearly trip to the mountains is going to be rough keeping up with the other guys. I dont know how to tell if its been lowered but I dont believe it has.
Get a shotgun shock. That will get the rear of the bike up and keep it from sagging. I put one on my sled. I air up in the corners and air down when cruising. Get ohold of Drew at Dr Vtwin. Hell hook you up.
Stone
Old Aug 15, 2011 | 12:33 AM
Bluehighways's Avatar
Bluehighways
When I read that some of you folks hardly ever scrape your boards I look imediately at where you live. It's really pretty simple, you flat-landers don't scrape your boards very often because of where you ride!
Old Aug 15, 2011 | 04:44 AM
grzly's Avatar
grzly
if you havent scraped a heritage floor board , then sorry , you should just move to a trike and be done with it
Old Aug 15, 2011 | 06:33 AM
sammer4u's Avatar
sammer4u
Originally Posted by jimmers1817
I must be doing something wrong. Hardly ever scape the boards even with Harleygoodies floorboard extenders and lowering it an inch.
Same here.. Although I have scraped three times total in 2 years.. in all three times I was very aggressive with the turns.
Old Aug 15, 2011 | 07:56 AM
kzoo's Avatar
kzoo
This is my first summer with the Heritage. I occasionally scrape the boards, if I am aggressive in the turn. However, with all the "road snakes" marking almost all the roads in my area, it is difficult to trust my stock dunlops enough to do it too often.
Old Aug 15, 2011 | 09:33 AM
Quadancer's Avatar
Quadancer
Dunlops are scared of tar snakes - they like to jump over them! Makes you a bit queasy if you're on the boards.
Old Aug 15, 2011 | 09:56 AM
dizzy1450's Avatar
dizzy1450
Originally Posted by av8or
It's a cruiser. Slow down and enjoy the scenery.
This.
Coming from sportbikes, it took me a while to realize I don't have the lean angles I used to have.
Scraping boards is no big deal. Lets you know you've reached the bike's lean limit.
Old Aug 15, 2011 | 10:09 AM
asm481's Avatar
asm481
Cut down on scraping by leaning your body into the curve more. Putting your weight into the curve makes the bike able to be straighter up in the curve.
