Primary Chain Stretch
Old Aug 24, 2011 | 02:24 PM
Bonaro's Avatar
Bonaro
Default Primary Chain Stretch
I have a 2001 fatboy big twin with a lot of performance mods. I had the primary cover off to replace the ring gear and noticed that the chain seemed like it had a lot of stretch in it.
I dont know what is acceptable but the deflection from level is about 1" to 1.25". The tensioner is still taking up all of this slack but Im not sure how much is too much.
Also, if you replace a stretched chain do you also have to replace the drive and driven gears?
Old Aug 24, 2011 | 02:56 PM
95yj's Avatar
95yj
You do not have to replace the gears if you replace your primary chain. The rule of thumb on replacing the primary chain is that if you can adjust the chain tight to specs (or your auto tensioner does the same), it doesn't need to be replaced yet. HD manual says basically the same thing.
sgw1064
Jan 8, 2023 09:19 PM
cgmartine
Apr 21, 2013 08:54 PM
jpooch00
Dec 21, 2012 08:24 AM
langlois1
Jun 25, 2009 04:52 PM
DaShoveled one
Feb 8, 2008 11:18 AM
