Caught in the rain
Old Aug 24, 2011 | 05:39 PM
Springermoneypit's Avatar
Springermoneypit
5th Gear
Default Caught in the rain
Saw the storm comin, kept goin anyway. So now she spits and sputters at low rpm. I have drained the tank, and fuel bowl. Put in a new fuel filter and still shes mad at me. Any ideas are appreciated.
Also gave new royal purple in tank and primary, and new plugs just cuz I luv that evil bitch.
Old Aug 24, 2011 | 05:50 PM
jbg's Avatar
jbg
Water probably got in through the air intake. I don't think it's in the gas.
Old Aug 24, 2011 | 06:01 PM
mike 09's Avatar
mike 09
My guess would be electrical
Old Aug 24, 2011 | 06:08 PM
dieselguy65's Avatar
dieselguy65
pull the air filter. bet it got wet. after that start checking plug wires, and all the connections in the harness, starting with exposed ones first
Old Aug 24, 2011 | 06:14 PM
Blk and Chrome's Avatar
Blk and Chrome
injected or carb?
Old Aug 24, 2011 | 06:22 PM
Springermoneypit
5th Gear
1999 springer, factory carb
Took air filter off and ran for a few miles, but it still the same.
Have started checking elect connections now
Thanx for the ideas
Old Aug 24, 2011 | 07:26 PM
Blk and Chrome
ck the electrics under the seat and the module leads they could have got wet
Old Aug 24, 2011 | 08:07 PM
imboden's Avatar
imboden
I'm with the others, pull the air filter and run it, see how she does. go from there!
Old Aug 24, 2011 | 08:27 PM
jlasoftail's Avatar
jlasoftail
clean all your main electrical connections, but don't be surprised if it just clears up after a few days of drying. Even if it does, you'll want to try to figure out the cause.
Old Aug 29, 2011 | 07:50 PM
Springermoneypit
5th Gear
Well, while riding at night I saw a spark under the dash, got home and pulled the dash, and found a crack on the terminal of the ignition switch. Replaced it and it's all good.
Now the starter went out
Like they say, if it was easy, everyone would do it.
Thanks for everyone's help!!!!!!!
