Engine pings
Old Aug 30, 2011 | 02:25 PM
Tracker56's Avatar
Tracker56
I doubt the HD guys would "catch it" because their Stage I flash is EPA compliant, therefore lean. If it meets spec then they're going to call it good. You have to get away from the H-D flash and go with a custom tune to get rid of the lean condition.
Old Aug 30, 2011 | 10:27 PM
t stone's Avatar
t stone
That makes sence. I use an auto tune on my mountain sled, and then download to my PC5. I stay away from the factory tune because of to many motor failures. Do you know if there is an auto tune for the screamin eagle tuner?
Stone
Old Oct 6, 2011 | 11:28 PM
mswing1234's Avatar
mswing1234
OK...after installing my V&H BR 2-1, SE Heavy Breather, and FuelPak...no pings what-so-ever.
Old Oct 7, 2011 | 02:36 PM
oct1949's Avatar
oct1949
U may not be lugging U motor, but U just might be giving her too much throttle while just putting alone in 5th or 6th. Try 1/2 or 3/4 throttle.
Seldom do I go full throttle under 2500 rpm's in 5th or 6th, though I can (cams and good dyno made a big diff) if U need to accelerate fast U might just drop a gear and see if it still pings.
Old Oct 7, 2011 | 07:03 PM
pnw_hd_rider's Avatar
pnw_hd_rider
Originally Posted by parabellum_9x19
If the ping is detonation, wouldn't a set of XiED's richen him out just a bit and help to prevent this?
Pinging is from pre-ignition, not detonation. The two are often confused with each other but they are two entirely different things.
HDF Tech
Engine Mechanical Topics
50
Jun 9, 2023 09:42 PM
rfranz1952
Exhaust System Topics
Aug 17, 2021 03:16 PM
jmd897
Jun 8, 2017 10:58 AM
Deckman
Feb 16, 2017 11:28 AM
Seascape
Oct 8, 2008 10:07 PM
