Torque specs. please !
Old Feb 18, 2018 | 07:15 AM
Gsomerville's Avatar
Gsomerville
6th Gear
Originally Posted by Rakthi
That's what is says in the 2007 manual too, but my 2009 manual states what
Malinger posted : initial torque 60 ft lbs. Back off 1/2 turn then torque to final of 77-83 ft lbs.
2009 manual also states to discard the front axle nut and get a new one for the xbones.
i have a 2009 Softail models owners manual and can’t find the wheel torque specs. Is there a different manual? I’ve went through it twice now... haha maybe I’m just an idiot! I have an 09 Deluxe
Old Feb 18, 2018 | 07:18 AM
QC's Avatar
QC
The owners manual is not the same as the service manual.
Old Feb 18, 2018 | 08:24 AM
Bone Doc's Avatar
Bone Doc
As QC pointed out, you need the SERVICE manual. You have the OWNERS manual.
This is the service manual for 2009 Softail models. It is HD part number 99482-09. It is only available in print. There are no electronic forms of Harley manuals. You can search eBay for a copy, order one through your local dealer or an online Harley dealer.
Old Feb 18, 2018 | 11:40 AM
Gsomerville
6th Gear
I appreciate it! I was able to locate the service manual and download it. Thanks again
Old Feb 18, 2018 | 11:41 AM
TwiZted Biker's Avatar
TwiZted Biker
Originally Posted by Malingerer
Front axle 60-65 ft lbs. Rear axle 95-105 ft pds. Pulley bolts initial torque 60 ft lbs.Back off 1/2 turn then torque to final of 77-83 ft lbs.
And don't forget the red loctite on the pulley bolts.
Old Feb 18, 2018 | 11:42 AM
TwiZted Biker
Originally Posted by oct1949
Also I thought I seen in here to use the blue loctite,, the one that breaks away if needed.
Not on the pulley bolts always use the red, blue will just hammer loose.
Old Feb 18, 2018 | 03:56 PM
Gsomerville
6th Gear
red loctite on the pulley bolts!! Thanks man
Msquad
2018+ Softail Models
May 18, 2019 07:17 AM
peddler
Mar 8, 2017 08:56 PM
Titan56
Jun 22, 2012 08:50 AM
Roadie09
Jan 1, 2010 02:19 PM
128auto
Aug 17, 2008 02:42 PM
