Torque specs. please !
Old Aug 29, 2011 | 04:38 PM
Tims05's Avatar
Tims05
Stage III
Default Torque specs. please !
Hi there I have a 08 Cross Bones and need to know the torque specs. for the front/rear axle and drive pulley. Maintence book has been ordered but I have mounted new tires yeaterday and dont want to wait for its arrival. Thanks. Tim
Old Aug 29, 2011 | 07:18 PM
Malingerer's Avatar
Malingerer
Front axle 60-65 ft lbs. Rear axle 95-105 ft pds. Pulley bolts initial torque 60 ft lbs.Back off 1/2 turn then torque to final of 77-83 ft lbs.
Old Aug 29, 2011 | 07:36 PM
Tims05's Avatar
Tims05
Stage III
Thats it. Thanks
Old Aug 29, 2011 | 08:01 PM
cmosentine's Avatar
cmosentine
My manual specs 55-65 ft/lbs for the rear sprocket screws. It also says to always use new screws.
Old Aug 29, 2011 | 08:12 PM
Rakthi's Avatar
Rakthi
That's what is says in the 2007 manual too, but my 2009 manual states what
Malinger posted : initial torque 60 ft lbs. Back off 1/2 turn then torque to final of 77-83 ft lbs.
2009 manual also states to discard the front axle nut and get a new one for the xbones.
Old Aug 29, 2011 | 08:18 PM
Malingerer's Avatar
Malingerer
My info was from the 2010 Softail Manual
Old Aug 29, 2011 | 09:03 PM
oct1949's Avatar
oct1949
Also I thought I seen in here to use the blue loctite,, the one that breaks away if needed.
Old Aug 29, 2011 | 09:11 PM
Bluehighways's Avatar
Bluehighways
+1 on Blue Loctite. Also a light film of Chassis Grease on the Axle Shaft (but not the threads).
Old Aug 30, 2011 | 06:45 AM
cmosentine's Avatar
cmosentine
+1 on blue LocTite. Also remember to reduce the torque by about 20% is using LocTite or anti-seize due to the lubrication of the threads.
Old Aug 31, 2011 | 03:05 PM
Tims05's Avatar
Tims05
Stage III
+1 on the blue loctite. Still no manual but I have not heard about replacing the pulley bolts. I suspect grade 8's will do? I took the bike out for a test ride but will replace the bolts if needed. Thanks for all the replies. Tim
