Brake/run/turn kit installation
Old Sep 7, 2011 | 10:48 AM
cmosentine's Avatar
cmosentine
Default Brake/run/turn kit installation
Hi all. I am looking at purchasing the HD brake/run/turn kit for my fatboy. I have not been able to view the installation instruction as HD as not provided them on the web site. Does anyone have the instructions that they could post? My big question is where does the module go?
Old Sep 7, 2011 | 10:52 AM
SMF's Avatar
SMF
Under the seat, it should Plug into your tail light harness
Old Sep 7, 2011 | 10:59 AM
MattInFla's Avatar
MattInFla
Installed one on my EGC. The instructions were very similar for the Softtail.
Remove Seat. Disconnect battery. Unplug tail light connector under seat. Plug Run-Brake-Turn module into tali light connectors. Zip tie module to a convenient spot under the seat. Connect battery. Put the seat back on. Change turn signal lenses. Ride.
Old Sep 7, 2011 | 11:07 AM
cmosentine's Avatar
cmosentine
Thanks for the replies. Makes sense.
Old Sep 7, 2011 | 02:47 PM
Skeezmachine's Avatar
Skeezmachine
It's about as simple an install as you can get. As stated, you remove the seat and you unplug the rear wiring harness (the plug is right behind the battery and in front of a hole in your rear fender where the rear wiring harness passes through). Then you just plug the module in (this should be self explanitory once you see it) and tuck it behind the batter. Mine fit snuggly and there was no real need to zip tie it but that is up to you. Then you just swap out your rear lenses for the red ones that come with the kit.
Old Sep 7, 2011 | 04:15 PM
dieselguy65's Avatar
dieselguy65
thats about it. i used the kuryakin one, but same deal.
Old Sep 8, 2011 | 01:22 AM
billsantos's Avatar
billsantos
FYI.. If you got the HD kit, the turn signal lenses are not diffused like the tail light. Least the kit for my ST were not. You might find them looking way brighter than the tail/brake light (I did). You can replace the turn signal 1157 bulb with a lower wattage 1157.. Stock is 24W, but they make a 18 and 12 watt. I ended up with 12's for a perfect match at night.. 18's pretty good to.. Like $4 a pair.
Old Sep 8, 2011 | 10:51 AM
bkelly1956's Avatar
bkelly1956
I currently have smoked lenses on the rear signals and like their look. If you use this module are the red lenses required by law enforcement?
Old Sep 8, 2011 | 10:58 AM
cmosentine's Avatar
cmosentine
I am now looking at going with the Badlands LED setup instead of the HD solution. Anyone have thoughts on their quality?
Old Sep 8, 2011 | 11:01 AM
JPL's Avatar
JPL
Are you guys doing this as a substitute for the tombstone brake light?
