Handle bar question and forks question Rocker C
Old Sep 7, 2011 | 12:15 PM
ironmike666's Avatar
ironmike666
Default Handle bar question and forks question Rocker C
Very new to bikes. Have an 08 Rocker C. I'd like to know if anyone has the specs for the stock bars(so I have something to go off of for getting a better bar for my lanky arms)
And also need to know what I need to look at when i go to buy a springer front end. Is there a particular size I need for the neck? Or are all necks the same size? ANy help is greatly appreciated.
Thanks in advance
Old Sep 7, 2011 | 01:24 PM
Kowan's Avatar
Kowan
The stock bars are two piece and with the angled riser/clamp, you're looking a custom fab shop to make bars to use the stock risers.
The risers are typical 3.5 inch center to center, so replace the risers with a more conventional riser to allow almost any bar made to fit.
HD makes a shorter drag bar for the Rocker.
I don't think anyone has gone with a springer frontend on a Rocker because it's narrow enough the hit the stock fuel tank.
Old Sep 7, 2011 | 05:12 PM
ironmike666
Thanks for the info.
I dont quite understand how the springer would hit the tank? Can u explain that to me please.
Old Sep 7, 2011 | 06:01 PM
Rodzilla6's Avatar
Rodzilla6
HD also makes a set of apes that fit the rocker also. They are in the HD parts catalog. I have an 08 rocker also and LOVE the bike, BUT be careful, I have had 2 sets of rear bearings fail, first set after 6500 miles and the second set after 7000 miles. The second at 60 MPH on a corner/scary/$1200.00 damage...The ones they put in at HD are from China. Timken and ALL ***** make high quality bearings for less than $30.00 for all 4. A bunch of Rocker owners have had the same issue/I would not take a chance. Ride safe.
Old Sep 9, 2011 | 09:02 PM
ironmike666
Thanks a million Rodzilla. I'll be gettin them replaced next service.
Cliffy Amo
Aug 18, 2014 12:56 AM
BK26_SLICK_SG
Jan 17, 2012 04:03 PM
09RockerC
Mar 7, 2009 06:29 PM
Phatts
Feb 15, 2009 08:34 PM
kiteman
Dec 18, 2008 05:27 PM
