Samson pipes installed
Those look sweet -- can you get them w/out the fishtail caps? I think the true duals look great on the Heritage, they fit the bike and the look. Have fun man!
I think they have newer true dual cross overs that are not listed S-330.
SMSgt B, how did the install go? Give some details on the install.
1. Make sure you setup your new bent shifter rod prior to installing the left side.
2. Take your right footboard off and loosen the rear brake bracket...makes it easier.
3. No need to remove passenger footboards
4. You have to remove 2 plastic covers on the left side where you mount the rear bracket (exactly opposite of the right side exhaust mount). Those darn things are a bare to get
out.
I ended up just tearing off the top and pushing them threw the back side.
5. It took me a long time because I tried to hide the heat shield clamps as much as I could...this put them in some real tight spots. Looking back..just mount the darn things where
you can get to them EASY
All-in-all, great fit and excellent sound and completely happy.
I will get some better pics after I install some more stuff and clean it.
V/r
The fishtails look good...yoiur wife will warm to them...or not!
