Any softail evo riders?
Old Jan 24, 2012 | 11:39 AM
  #31
str8jacket's Avatar
str8jacket
Originally Posted by Airpump
I did try it,,, and I didn't like it!!!! Every Softail that I have tried out had an annoying buzz around 70+ mph because of the counter balancers not to mention the excessive heat when hung up in traffic.
Mine runs smooth at 70+ without any "buzz". Much smoother than an Evo. With the 88 motor, I've not experienced any excessive heat either.
Also, I don't think I would be to fond of the cam chain shoes when they decide to go south and wipe out my engine. Guess you are one of the luckly ones.
Ride safe
One of the lucky ones? Luck has nothing to do with it. It's a maintenance issue. Not doing proper scheduled maintenance is always going to be problematic with any motor. Just like if you let a leaky Evo motor run out of oil and damage the motor.
Old Jan 24, 2012 | 07:07 PM
  #32
Airpump's Avatar
Airpump
Maintanence Item, I would suggest that you spend some time in the technical section and freshen up on the cam chain tensioner issues with and without the proper maintenance schedules being performed.
Heat problems with all Twin Cams has been an issue since the engine was introduced. If you don't have a problem with excessive heat then as I said before, you are one of the lucky ones.
Leaky Evo. LOL!!!! I think you are referring to the shovel engines and earlier.
Old Jan 24, 2012 | 09:00 PM
  #33
97HeritageSpringer's Avatar
97HeritageSpringer
On the "leaky EVO" thing - if you can find a leak on my EVO, you can have it! Mine doesn't leak a drop.
Old Jan 24, 2012 | 09:21 PM
  #34
Airpump's Avatar
Airpump
Neither did the two others that I owned. Additionally, I believe they also earned the name "Bullet Proof" during the fifteen year run, not leakers.
Old Jan 25, 2012 | 12:54 PM
  #35
str8jacket's Avatar
str8jacket
So apparently you are a resident expert on the TC motor. Just how much of this vast knowledge comes from actual personal experience? How many miles have you actually put on a TC Softail to be such an expert? I have ridden a substantial number of miles with both an Evo and a TC motor. The Evo motor also gets hot when stuck in traffic for an extended period of time. In my experience, the 88 TC doesn't have any "heat problems" as long as it's jetted/tuned properly.
If bashing the TC motor makes you feel better about yourself, then I guess that's what you're going to continue to do.
I think you missed my point. I never said that ALL Evo motors leak. I said if you let a leaky one run out of oil, it would damage the motor. If you replace a cam chain tensioner before it wears to the point of metal on metal, it won't cause any damage to the motor.
Are you saying that all Evo motors are leak free? I haven't seen one yet with over 40k with original base gaskets and rocker box gaskets that didn't leak oil. In no way am I saying that they ALL leak oil.
Old Jan 25, 2012 | 03:24 PM
  #36
Airpump's Avatar
Airpump
First off I never said anything about being an expert. Read into it what you will but drop the attitude. I learn to read in grammer school and have no problem searching out technical information reference an item before I sink $$$$$$$$$$ into it, whatever the product may be.
No miles whatsoever on a TC softail, didn't you happen to notice what I said in my earlier post?????
Reference the heat difference between the Evo and the TC do some research and make up or own mind. Don't try to tell me the Evo generates the same amount of heat as the TC. I really don't care how many $$$$$$$ you spend on jets or how many different maps you install. Every hear anything about "HEAT MANAGEMENT", if not you find out about it as you learn the real difference between the Evo and TC engines.
You will also learn about the numerous numbers of owners who have had tensioner shoes fail while using the best oils available. Miles doesn't seem to be a factor in the shoe wear, some have fail as early as 10,000 or less. Some have gone over 50, 60 or more thousand. There doesn't seem to be a good answer. Maybe the new hydraulic tensioners will improve the overall problem with the shoe life.
By the way, I have also purchased three new Electra Glides an 03 FLHTCI, 04 FLHTC and a 06 FLHTCI, Of the three the FLHTC ran the coolest after a few trips into the carb. As for the injected models I added the Dyno Jet Power Commanders to both without any success in eliminating the heat problem. Just a waste of money after installing a number of can maps and one trip to the local dyno expert.
Of the three Evo's that have pass through my garage none have every had the base, push rod or rocker covers gaskets replaced. Of the three my 84 1/2 FXRS Disc Glide had the most miles 68,943 and was still performing leak free when the new owner left with it.
Old Jan 25, 2012 | 03:53 PM
  #37
Nabubba's Avatar
Nabubba
Well let's look at what you said you want it for a barhopper and occasional cruiser. Well then vibration shouldn't even be an issue on either of those. Now if you were doing long distance touring or endurance rides then some vibration may be an issue. I ride my '88 FXSTC everyday and have put as many as 6-700 miles on it in a day and I feel ready to go a few more at the end. But it is all subjective in nature what is not an issue for me may be one for you.
Old Jan 25, 2012 | 04:29 PM
  #38
str8jacket's Avatar
str8jacket
Yes I did "happen to notice". It is the one I quoted in my response.
This post where you implied that you have ridden one:
So you went "no miles whatsoever" at 70+ mph when you encountered this "annoying buzz" you speak of? And "I did try it,,, and didn't like it" means what... you sat on one?
The fact is, you're doing a lot of ranting about something you have absolutely zero first hand experience with.
Old Jan 25, 2012 | 04:36 PM
  #39
SeeMeDo's Avatar
SeeMeDo
I sold my 95FLSTN sure it shook but if I wanted less vibration I would have picked up a Honda.
Old Jan 25, 2012 | 05:33 PM
  #40
Airpump's Avatar
Airpump
Well said!!!
