Thoughts on Grip Ace and Exile Cycles internal throttle after a few hundred miles
Old Feb 24, 2012 | 04:00 PM
Deadanimal's Avatar
Deadanimal
Originally Posted by mimo
They do take orders for custom handlebars, yo can get them anyway you want.
@Malingerer, yes, there is a simpler but more expensive way to do this and it is getting Cyril Huze apes which come with everything pre-wired internally (clutch, brake lines, electrical and throttle/idle) those are plug and play but you have to convert your clutch from mechanical to hydraulic, easy to do, there are several systems in the market.
The Huze's setup is beautiful the switches are concealed and you only see flawless smoth lines from grip to grip.
Check 'em out:
http://store.cyrilhuze.com/CyrilHuze...roductID=10225
http://store.cyrilhuze.com/CyrilHuze...roductID=10231
Mimo.
Here is the response I got from Carlini on making custom order bars!
Hi Daniel,
I'm sorry but we can not make the bars without it. Raw piston risers are no problem.
Thanks,
Rex
--- On Fri, 2/17/12, Daniel Georgianna <deadanimal_@hotmail.com> wrote:
Subject: RE: A message from your contact form
To: teamcarlini@yahoo.com
Date: Friday, February 17, 2012, 12:21 AM
Hello again,
I'm still deployed at the moment so don't have access to a good phone as of yet but am hoping you could answer a couple of questions.
I've decided on a set of your apes but ams doing a clean set up with no control pods on the bars, I can't find any detailed pics of the bars but it looks like they taper down at the ends where they drop it 1" .
I'm using grips that are 1.50" and want to know if I can get a set of raw bars that have no taper and just drop to 1" so the bars and grips will appear to be seamless.
I am also curious if I can get a set of Piston risers RAW as I need to do some fitment work to the bars and then have everything PC'd the same color black.
And what extra cost would be involved.
Thank you so much,
Daniel
So much for custom orders.
I'm just gonna buy a raw set and chop them down to what I need and make inserts to drop from 1.50" down to the 1" with out having a taper to them...
Old Feb 28, 2012 | 10:33 PM
mike lhc's Avatar
mike lhc
Thumbs up
Very clean!
Old Feb 28, 2012 | 10:37 PM
mimo's Avatar
mimo
Hi Daniel,
Thanks,
Rex
Hello again,
Thank you so much,
Daniel
Bummer, looks like the guys at Carlini are swamped with work. I personally picked up my set of Flyin' apes back a while ago, Rex took care of me. Back then they had a special order service.
Good luck.
M.
Old Feb 29, 2012 | 10:03 AM
Leech1107's Avatar
Leech1107
Hi Daniel,
Thanks,
Rex
[/INDENT]
You may want to try BR custom bars he can do a lot of different things to your specs. But i just put gangster apes on my Lo and they are beautiful. So i can see why you want Carlini bars.
Old Feb 29, 2012 | 01:11 PM
Big H's Avatar
Big H
All that work sure smoothed out the appearance of your handlebars. It took you some time, but it looks like it was all worth it.
Old Mar 14, 2012 | 10:34 AM
jcallesano's Avatar
jcallesano
Id like more info on this install and more pictures. I plan on starting this in the next two weeks.
Just waiting on my joker machine controls and my grips to get sent back to me from GA. 30+ days out still....
Old May 14, 2013 | 10:32 PM
smrta$$ytboy's Avatar
smrta$$ytboy
Default brake Idea as well
I know this is an older post but you can go one step further to add to your seamless look and use a proportioning valve from wilwood off your foot brake master cylinder to a "T" then directly to your front brakes like I did on my chopper and shave that master cylinder off your handlebars as well. Just a thought. Great post though. Im buying the exile internal now because of this post.
Old May 15, 2013 | 01:03 AM
WhiteNoise's Avatar
WhiteNoise
****in clean man nice!
Old May 15, 2013 | 03:15 AM
jreichart's Avatar
jreichart
You would need to upgrade your rear master cylinder to an 11/16 bore, but yes it can be done. I think Exile even makes a setup for exactly that. I thought about going that route, but decided on the foot clutch instead, and the two do not coexist very effectively. I just opted to rUn the brake line in the bars to clean it up as much as possible.
Old May 15, 2013 | 08:08 AM
tbonetony06's Avatar
tbonetony06
Hmmm, I'm not happy to learn that I have to cut and weld on my new bars to make the internals work. I knew I would have to drill some holes, smooth them out but not the other. OH well, no turning back now. I have a question, why is your front brake line not run through the bars too?
